Old 06-12-2019, 07:08 PM   #1
lorenallen
Default LED head lights
I just installed a new wiring hardness in my 31 Cabriolet and at the same time I installed LED head lights. Last night I drove the car for about 40 miles in the dark and the LED lights performed very well. The high beams seem to work very well and light up the road better directly in front of the car. These install directly into the original sockets and this makes it very easy. My car is 12 volt negative ground if this makes any difference, so I order the 12 volt LEDs. I just thought I would pass on this information.
lorenallen is offline   Reply With Quote
Old 06-12-2019, 09:43 PM   #2
30 Closed Cab PU
Default Re: LED head lights
So what brand are they?
Old 06-13-2019, 05:30 AM   #3
1938 Woody Cape Cod
1938 Woody Cape Cod's Avatar
Where did you purchase the bulbs................Bob
1938 Woody Cape Cod is offline   Reply With Quote
Old 06-13-2019, 12:14 PM   #4
lorenallen
I bought them from Brattons.
Old 06-13-2019, 05:42 PM   #5
rfitzpatrick
I looked at Brattons and can not find them -- perhaps you have a part number you can share?
Thanks
rfitzpatrick is offline   Reply With Quote
Old 06-13-2019, 05:56 PM   #6
30 Closed Cab PU
This is what I found at Brattons online.
https://www.brattons.com/led-headlight-bulb.html
If you buy/try them, please post a review. I have the logolites, but am on lookout for something that focuses better.
Old 06-13-2019, 06:39 PM   #7
rfitzpatrick
I allready have led parking lites -- just ordered the head lamps. PM your email and I'll send pictures of what the parking lites look like. I've never figured out how to post pictures. The parking lites are really bright, I run them more to mark my presentsThans
Old 06-13-2019, 06:55 PM   #8
lorenallen
the LED head light bulbs are part #17994 and they cost $29.95 each. I replaced the reflectors, sockets, connectors, gaskets, focus spring and screw - everything for the head lights and it gets a little expensive but I am glad to have everything installed as it should be for the first time since I have owned the model A. The headlight terminal ends ( 3 on each side) are a challenge to solder in and keep all wires exactly the same length.
Old 06-13-2019, 11:13 PM   #9
30 Closed Cab PU
Am only interested in the headlights, have converted to all LED. But like I said, keeping my eyes open for reports of focusable headlights, the logos do not focus well.
Old 06-14-2019, 08:14 AM   #10
ryanheacox
ryanheacox's Avatar
My guess is they are LogoLites. Just about the same price and the other vendors are selling them too.
Old 06-14-2019, 10:37 AM   #11
old31
Has anyone found a LED parking bulb that works with 2 bumps on the bulb?
All the leds I tried are too long and hit the glass. I use the lamps for both parking and directionals.
old31 is offline   Reply With Quote
Old 06-14-2019, 10:55 AM   #12
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
There is no question that these are NOT ready for model a's at all, They are NOT focusable and cannot be aimed correctly, There is no high beam it is only a bright beam with more filaments, there have been extensive reviews on these and you can see them on the ford vintage. They only spread the light same as an LED in your backyard...it only lightens the area and not the direction you drive....I have done an extensive experiment on these IMHO..
Mark Maron
Ill., Region MARC & MAFCA
MARC JSC Member MAFFI Trustee
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 06-14-2019, 11:34 AM   #13
Kurt in NJ
Kurt in NJ's Avatar
It can be made to work, I have idea, but not much incentive, it will be more $$ than most will be willing to spend, but my now headlight project is playing with HID bulbs, they will focus with original reflector
Old 06-14-2019, 01:04 PM   #14
CarlG
CarlG's Avatar
I had the same problem. Third time was the charm.
I finally found mine at:
http://www.dynamoregulatorconversion...bulbs-shop.php
Part # CE1A, 12v 21/5w BAY 15D Amber White - Neg Earth
(They do have the equivalent in 6 volt positive as well)
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 06-14-2019, 04:12 PM   #15
Dave in MN
Dave in MN's Avatar
Just purchased a set of LED's headlights and new harness set from Snyder's.
Just purchased a set of new reflectors from Bratton's.
The 6 volt Halogen set I have been using for the last 15 years has melted the bulb plug resulting in arcing of the contacts about 4 times over this period. This spring, both left and right are in need of replacement again on my Phaeton. I thought I would try the LED's...If they don't work, Ill buy another set of plugs for the Halogen bulbs.
The only plugs available now are made from a "plastic" and do not handle the heat produced from the 6 volt Halogen bulbs. I used to purchase the "Bakelite" like plugs and they would last twice as long. Cannot find them anymore at NAPA.
Good Day!
Dave in MN is offline   Reply With Quote
Old 06-14-2019, 04:52 PM   #16
Kurt in NJ
Kurt in NJ's Avatar
I use the direct fit halogens with original sockets---- I did rewire with heavier gauge aircraft wire, 45 years ago, no socket melting in 15 years of halogen use
I suspect you have H4 bulbs , they can be higher amperage, ---- I will look in some benz headlights to see what they used for sockets with h4 bulbs
Old 06-14-2019, 05:42 PM   #17
Dave in MN
Dave in MN's Avatar
Are you using 6 volt or 12 volt. The amp draw is about double on the 6 volt...causing the melting. (I purchase the 6 volt Halogen bulbs from Snyder's...I have not looked at the manufacturer.) I have a set of 12 volt Halogen on my other car and have had no trouble with them.
Thanks for commenting!
Good Day!
Old 06-15-2019, 07:20 AM   #18
scokeing
scokeing's Avatar
I order these to try, can’t vouch for their fit yet however the dimensions show they should
https://www.ledlight.com/g18-s25-6-2...-polarity.aspx
scokeing is offline   Reply With Quote
Old 06-15-2019, 09:58 AM   #19
Badpuppy
Has anyone found a LED parking bulb that works with 2 bumps on the bulb? All the leds I tried are too long and hit the glass. I use the lamps for both parking and directionals.
Look for 8- or 12-segment (SMD) bulbs. The 8 is about the size of a G6
incandescent (2-6 CP) The 12 is a bit of a squeeze, but will fit the cowl lamp.
Those bulbs fit, but that's all. No focus, no low beam. Just bright and brighter.
The ones from dynamo old31 mentions seem to be the best, but in another thread Karl said they wouldn't pass local inspection in NZ.
Old 06-15-2019, 10:35 AM   #20
Kurt in NJ
Kurt in NJ's Avatar
I have 6 volt system, perhaps the oversized wire is protective of the sockets, I think it is 12 gauge, I don't think high wattages are needed if the bulb/ reflector/lens match, I have been studying different headlights, and will try some HID bulbs, the Mercedes headlight without lens is H4, it has a plastic connecter, and it has not been a problem, looking at the reflector for the H4 it has 2 different curves. The center1/2 is for the high beam, the outer area for low beam, the shield on the bulb only allowing light to go to the upper part ---- I have concluded that the H4 bulb is not suitable to original reflector
I have a "order" in with some local body shops to get some factory led headlights to study
