Old 01-01-2018, 07:50 PM   #1
BillCNC
BillCNC's Avatar
Default Rear Float-a-Motor Mount Install Issue
Hey Guy's
I'm installing Rear Float-a-Motor Mount's,, … well I WAS, and wondering why these simple part's cannot be made correctly OR … well someone else might have a better idea than I.
Mounts on the bottom of the inside frame rail, angle forward, all parts are as per instructions, … NOPE, … FAIL, … All bolt holes are to high. Look at the pictures, it's the same on both sides.
SO, … what are the options?
a. Wonder why the heck 3 simple holes cannot be drilled correctly.
b. Modify the Parts to fit.
c. Modify all the holes in the frame and mounting plates on an 87 year old car.
d. Call up CW Moss and ask them what's up?
Regards
Bill
BillCNC is offline   Reply With Quote
Old 01-01-2018, 08:54 PM   #2
1955cj5
1955cj5's Avatar
Default Re: Rear Float-a-Motor Mount Install Issue
The answer is d.....Call them in the morning for sure....
Something obviously isn't right. I would not start drilling....
I put a set on from Bert's and they fit fine...
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 01-01-2018, 09:17 PM   #3
burner31
burner31's Avatar
I received float-a-motor from santa this year, to cold to install, will be watching this tread to see what happens.
Have not looked in the box yet, now I just hope I can sleep.
Keith
Shawnee OK
'31 SW 160-B
Old 01-01-2018, 10:30 PM   #4
Y-Blockhead
Y-Blockhead's Avatar
Originally Posted by BillCNC View Post
Hey Guy's
Regards
Bill
THAT's the problem right there. I avoid CW Moss and Vintique as much as possible...
Old 01-01-2018, 10:40 PM   #5
Y-Blockhead
Some other examples of their wonderful parts...
Old 01-01-2018, 11:19 PM   #6
Bill Cilker
Bill Cilker's Avatar
The rubber part that goes between the frame and the Float a motor should be L shaped (A-5092). The same piece as used for original motor mounts. This will raise the FAM and the holes should line up
Bill Cilker, Jr
Unrestored 190A Victoria
45B, 160B & 189A
Victoria Association President
Bill Cilker is offline   Reply With Quote
Old 01-01-2018, 11:28 PM   #7
Mike V. Florida
Mike V. Florida's Avatar
YUP the answer is "D".
Old 04-19-2018, 07:43 PM   #8
duke36
There is only 1 rubber pad between the FAM outer plate and frame, no rubber pad inside the frame as shown in Brattons new redesigned kit, which fits very well. The key to the design are the new donuts ,which probably should be replaced every 5 years or so. One should compare all the vendors' kits to select a preference.
Old 04-20-2018, 07:05 AM   #9
marty in Ohio
marty in Ohio's Avatar
I read this post a couple times before I realized what Duke suggested. I've owned my car for about 25 years and it was restored MANY years before me. It has the Float-a-motor and I've never touched the donuts. Will new ones make a difference? And how so?
Marty
marty in Ohio is offline   Reply With Quote
Old 04-20-2018, 07:20 AM   #10
WHN
Good orginal motor mounts. 90 years, if there not broken why fix them?
Old 04-20-2018, 07:46 AM   #11
denis4x4
denis4x4's Avatar
Marty
Have FAM in two cars replaced the rubber last year after 18 and 14 years respectfully. Old rubber was harder than a hocky puck! Well worth it to use new rubber.
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 04-20-2018, 07:53 AM   #12
Growley bear
c) is NOT an option. If you modify the part then the warranty is null and void. If you enlarge the holes in your frame then that is a can of worms best left unopened.
Growley bear is offline   Reply With Quote
Old 04-20-2018, 09:32 AM   #13
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
I saw an OUTHOUSE, with SQUARE HOLES! I "guess" the builder didn't take GEOMETRY???
Bill Uncomfortable
"THE ASSISTANT GURU OF STUFF"
Old 04-20-2018, 10:12 PM   #14
Railcarmover
That's an interesting lower bracket.
earlier ones had a mild steel bracket and the aluminum donut holder.
Railcarmover is offline   Reply With Quote
Old 04-20-2018, 10:27 PM   #15
Mike V. Florida
I wonder what he did?
Old 04-21-2018, 06:45 AM   #16
marty in Ohio
Well, Railcarmover started me to thinking about the Float-A-Motor on my car. As near as I can determine it was restored more than 45 years ago. I can's even see the rubber donuts and the cap on the top is printed ANTIQUE and Rosemead, Calif. Does that make any sense to anyone?
Marty
Old 04-21-2018, 07:42 AM   #17
Keith True
Keith True's Avatar
That one is a first for me.All the directions I've seen say the lower bracket mounts directly to the frame,NO rubber on the inside.You did use the rubber between the outside plate and the frame though.I have a set on a truck that that was parked with them in it in 1954,when my uncle went in the service.Those are all steel,no aluminum.I had a bunch or partial sets of rubbers around because I had to buy a whole set and rob just the outside piece.Somewhere along the line at least one of the vendors started selling just the outside piece for people who were using floaters.
Old 04-21-2018, 07:51 AM   #18
V4F
V4F's Avatar
this is no help , but I found putting in new ones can be a chore . mine have no problem going in & out . the set that was so much work were new ones on another car . I had to use a punch the get the holes to line up . lots of patience & reading the instructions often .
good luck
V4f
V4F is offline   Reply With Quote
Old 04-21-2018, 12:19 PM   #19
burner31
burner31's Avatar
I used some longer bolts then the one supplied, once I got the bolt thru the mount and frame, and the washer and nut on I tightened them up and everything went together as designed.
I found the supplied bolts to be about 1/4 inch to short for ease of installation.
Keith
Shawnee OK
'31 SW 160-B
Old 04-21-2018, 01:21 PM   #20
daveymc29
daveymc29's Avatar
have a set with Rosemead Antique printed on them. Just replaced the rubber pads. Took 45 minutes with no issues. The old pads were hard as rocks and 1/8 inch compressed.
daveymc29 is offline   Reply With Quote
