02-20-2020, 09:22 PM | #21 |
Re: Centre exhaust port baffle or fourth port?
If i decided to use a port divider the type made by Dunn engineering a very long time ago would be my choice. The Dunn divider is not a heavy casting it was two U shaped channels made from stainless steel placed back to back and spot welded together and of course shaped like the port. This divider is extremely narrow which of course reduces the port restriction the divider will cause.
From what I have been able to get in the way of HP out of 292 cubes without the divider I feel its not worth the effort. Learn from what Pete wrote in post #14 theres more power to be gained by thinking outside the box. Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
02-20-2020, 09:37 PM | #22 | |
I should have mentioned you as well. Glad you posted some of your findings. |
02-20-2020, 11:33 PM | #23 |
Like others on this forum, I;ve tried many things and never knew if they worked, Pete Raced so he knew if a mod worked. Putting an engine on a dyno like JWL did for all his mods told him what worked and how much. There is one thing you must take into consideration is: what is the reason for thr mod, MAX HP?? That takes place at WOT. The only place you can use this us on a race track. I'm working on an engine for the street that I hope will make good power, and fuel economy , at avery reasonable cost, using all the information I;ve gained here and over 60 years putzing with these engines.. Might work, might not, but it's something to do.
Gramps (Formally O'l Ron) |
02-21-2020, 06:04 PM | #24 |
02-21-2020, 06:32 PM | #25 |
02-21-2020, 06:39 PM | #26 |
02-21-2020, 06:43 PM | #27 |
Yep, try a SBC with a healthy cam and zoomies!
02-21-2020, 07:29 PM | #28 |
To be specific, it was a Yamaha V-Max motorcycle. Half the cylinders and mufflers. My better half didn't speak to me for a week!
