Old 09-04-2017, 07:28 PM   #1
mrwarm
mrwarm's Avatar
Default oil pressure
Just wondering what is the normal oil pressre at idle and at driving 40 or 45 on a 29 stock motor. thanks
mrwarm is offline   Reply With Quote
Old 09-04-2017, 07:43 PM   #2
glenn in camino
glenn in camino's Avatar
Default Re: oil pressure
Oil pressure will probably be 4 to 5 lbs at 40 to 45 mph and 0 at idle. Some is better than none.
glenn in camino is offline   Reply With Quote
Old 09-04-2017, 07:48 PM   #3
Big hammer
Not much if any at idle, 40-45 mph maybe 2 or 3, stock pump is a volume not pressure pump. Check for flow by loosening the drain back tube from the valve chamber, have a pan under it :-)
get a bigger hammer tap done
Old 09-04-2017, 08:43 PM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Oil gauges on Model As, just make you WURRY!
Bill Noguage
"THE ASSISTANT GURU OF STUFF"
Old 09-04-2017, 09:31 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
You'll get lots of pressure if you restrict the open end of the oil flow tube, but the Model A only lifts the oil a foot, then lets gravity feed the mains and the rods splash it around.
Old 09-05-2017, 08:53 AM   #6
Bob Bidonde
Bob Bidonde's Avatar
The oil pump supplies oil to the reservoirs in the valve chamber. Gravity feeds the oil into the main bearings, the connecting rod troughs and the camshaft bearings. There is one exception. The center camshaft bearing gets oil directly from the pump.
The oil pressure that is essential is developed inside of the bearings, and it reaches thousands of PSI.
Bob Bidonde
Old 09-05-2017, 09:29 AM   #7
BILL WILLIAMSON
It's quite AMAZING that these engines did SO WELL, with such a system!
Bill W.
Old 09-05-2017, 06:09 PM   #8
old31
When I first start the car I am at 4lbs. After it warms up I am at 1-2lbs.
Old 09-05-2017, 08:04 PM   #9
Big hammer
Normal read post #4
Old 09-05-2017, 09:19 PM   #10
Simonpie
I always avoided getting an oil gauge, but this thread makes me wonder. Is there a nice "old-timey" looking oil pressure gauge that is 0-5 psi, or maybe 0-10 max?
Thanks,
Simonpie is offline   Reply With Quote
Old 09-05-2017, 11:16 PM   #11
Tom Wesenberg
Thanks,
Yes, I had one of each, but sold one of them.
Old 09-06-2017, 05:19 AM   #12
mrwarm
mrwarm's Avatar
thanks for all the input. As i previusly posted I dropped my oil pan and found lint covering my oil pump filter cleand it and put pan back on. car starts cold with 20 lbs of oil pressure as it warms it droppes to about 2 lbs at idle on road driving about 40-45 I have about 5lbs using 20w50w oil.sounds like im ok
Old 09-06-2017, 05:36 AM   #13
BILL WILLIAMSON
Remember, many gauges "might" NOT be TOTALLY ACCURATE!
Bill W.
Old 09-08-2017, 07:41 PM   #14
michael a
michael a's Avatar
This reminds me of the time I built a knucklehead Harley motor I asked an old fella they cut his teeth on them about an oil pressure gauge you said don't put one on that you won't sleep at night I have never forgotten that
Sent from my SM-J700T using Tapatalk
michael a is offline   Reply With Quote
Old 09-09-2017, 08:27 AM   #15
V4F
V4F's Avatar
HDs are roller bearing & the oil just flushes thru .
V4f
V4F is offline   Reply With Quote
Old 09-09-2017, 08:36 AM   #16
BILL WILLIAMSON
Mornin', V4F,
MANY years back, I "heard" that Porsches' "optional" CONTINENTAL Engine had a Roller Bearing lower end & you had to keep them revved MORE than the regular engine!
"Maybe" it was just a "MYTH"????
Bill W.
Old 09-10-2017, 06:21 AM   #17
WHN
Our 29 reacts just as yours, also using 20-50w HD oil.
WHN is offline   Reply With Quote
Old 09-10-2017, 09:58 AM   #18
Dick Steinkamp
Dick Steinkamp's Avatar
Originally Posted by BILL WILLIAMSON View Post
Mornin', V4F,
Bill W.
Not a "Myth", but a combination of two unrelated facts.
The Porsche Continental was a badge applied to the pre 356A cars imported to the US from October 54 to October 55. No special engine. All had the 55 HP flat four, pushrod. There was no "special" Continental engine.
The Carrera engine came along later in the 356's life and did have a roller bearing lower end (as well as 4 overhead cams). It was essentially a race only engine, but you could buy one in a street legal production car (very expensive). They would rev higher than a regular 356 engine and likely needed a fast idle due to the lumpy cams.
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 09-10-2017, 11:19 AM   #19
V4F
V4F's Avatar
if a engine has a roller bearing crank , your not going to see a lot of oil pressure .
V4f
