Old 10-04-2012, 10:11 AM   #1
wrndln
Default Finish on headlight parts
I am working on restoring some headlights for my 28/29 model A's. I have one apart (see picture below) and I think I know how it should be finished. I believe it should be zinc plated - all three parts, bolt, bracket and strap. Can someone confirm this is the correct plating for the parts?
Thanks for any help.
Rusty Nelson
Old 10-04-2012, 01:23 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Finish on headlight parts
They were cad plated the last time I looked at the standards.
Old 10-04-2012, 01:53 PM   #3
Arlen
Arlen's Avatar
I always cad plate mine. Turns out beautiful for a part nobody sees
DMAFC
Arlen is offline   Reply With Quote
Old 10-04-2012, 02:07 PM   #4
Marco Tahtaras
Marco Tahtaras's Avatar
It's easier to see in commercial headlamps.
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
Old 10-04-2012, 03:01 PM   #5
2manycars
2manycars's Avatar
Marco, it is interesting to see that those buckets seem to be painted over nickel plating. I wonder why Ford would waste time, money, and materials to plate, then paint. Are those from the end of 29 production, and painted to go on early 30 trucks?
2manycars is offline   Reply With Quote
Old 10-04-2012, 06:28 PM   #6
Marco Tahtaras
Those are showing bare steel. On the exterior there is corrosion but the inside is almost like new.
Old 10-04-2012, 06:29 PM   #7
wrndln
Speaking of headlights. I am trying to remove the clip on the top of some buckets so they can be plated. I don't see how the clips can be taken out. If I press down the top end, it becomes extremely taught and I can't get clip removed. There must be a way to do it, but I sure don't know it. I would like to save the clips and not damage them. Any suggestions?
Rusty Nelson
Old 10-04-2012, 07:50 PM   #8
d.j. moordigian
d.j. moordigian's Avatar
Rusty,
As I recall, some come out....I think the 3 wire do.
d.j. moordigian is offline   Reply With Quote
Old 10-04-2012, 08:15 PM   #9
wrndln
They do come out, I just don't know how to do it. The spring they are made from is very strong. Parts suppliers sell them.
Old 10-05-2012, 08:44 AM   #10
Farrell In Vancouver
Farrell In Vancouver's Avatar
Intersting strap location difference. Rusty's seem to go from the corner to the mid rivet, whereas Marco's pic shows the strap crossing mid to mid rivet. Wonder how many variations can be found on theses parts?
Farrell In Vancouver is offline   Reply With Quote
Old 10-05-2012, 09:13 AM   #11
wrndln
One difference in Marco's headlights and the one I posted is mine is a 28's with a single bulb reflector and Marco's are 29's with a two lite reflector. All the 28/early 29 headlights I have, have had the diagonal retaining straps. Note the larger hole for the wiring going into the headlight on Marco's headlights. It is kind of hard to tell the difference, but I have a number of each type and the larger hole is about 1/8" larger in diameter. There might have been different suppliers also, but I guess it doesn't make much difference as the straps aren't seen once assembled.
Rusty Nelson
