Old 05-11-2019, 02:39 PM   #1
johndee138
johndee138's Avatar
Default 1936 spare cover trim clips
A while back there was a discussion about where to find 36 spare cover stainless trim clips. I can't seem to dredge it up.
Anyone know where I can find some or something that will work?
johndee138 is offline   Reply With Quote
Old 05-11-2019, 03:03 PM   #2
mrtexas
mrtexas's Avatar
Default Re: 1936 spare cover trim clips
I've got some, email me.
41 woodie https://41fordwoodie.weebly.com/
mrtexas is offline   Reply With Quote
Old 05-11-2019, 04:16 PM   #3
Don Rogers
Don Rogers's Avatar
John, Here is a picture of an original and Auveco replacement
Don Rogers is offline   Reply With Quote
Old 05-11-2019, 07:14 PM   #4
mrtexas
mrtexas's Avatar
How many clips per ring?
Very popular post. I have 4 responses already and my ring/clips weren't even for sale!
I have 15 clips in Rust 911. I should know by tomorrow how many are good. Seems to me the motivated restorer could make some by welding a small bolt to a strip of sheet metal the correct width.
I see Macs lists the ring and clips as discontinued. Lucky I got mine when I did!
Old 05-11-2019, 11:40 PM   #5
deuce lover
deuce lover's Avatar
Takes 9.Couldn't find any so I made mine from tiny rivet nuts that Drake sells.Southside Obsolete in MN might have some originals.
Here is a pic of what I did and it worked for me.I ground down the head. Drake part number 1160-R.
deuce lover is online now   Reply With Quote
Old 05-12-2019, 07:42 PM   #6
Gary Tosel
Gary Tosel's Avatar
I have found that the reproduction trim ring needs to be installed using the clips provided. Stock clips will not fit, since the reproduction ring is more narrow than the stock ring. Since the reproduction trim rings are no longer in stock, good original rings are out there, but getting harder to find in good condition.
Gary Tosel is offline   Reply With Quote
Old 05-12-2019, 09:08 PM   #7
mrtexas
mrtexas's Avatar
I've got a good original ring and 9 original clips for sale in the want ads https://fordbarn.com/forum/showthread.php?t=263268
Old 05-12-2019, 09:13 PM   #8
mrtexas
mrtexas's Avatar
Just measured 0.38 original vs 0.35 repro width on the outside.
Old 05-18-2019, 10:51 PM   #9
cajunfirehawk
cajunfirehawk's Avatar
Question Re: 1936 spare cover trim clips
Looking for rings and clips....any suggestions?
Regards,
Todd
1936 FORD Tudor Slantback
"cajunhotrodder" on instagram/youtube
cajunfirehawk is offline   Reply With Quote
Old 05-19-2019, 09:55 AM   #10
mrtexas
mrtexas's Avatar
My clips and ring are sold. Watch ebay
Old 05-19-2019, 11:08 AM   #11
cajunfirehawk
Exclamation Re: 1936 spare cover trim clips
I live on ebay, only see the rings on old spare tire covers, I actually have a beat up one I could use but still need some clips, was considering silicone or gorilla glue as a last resort since mine isn't pristine
Regards,
Todd
Old 05-19-2019, 11:32 AM   #12
cajunfirehawk
Thumbs up Re: 1936 spare cover trim clips
Thanks to "deuce lover" for the substitute clips info/pics from Drake which I ordered, not complaining but saying Bob Drake, $20 freight IS a lil excessive for 4 packs of small hardware which can fit into a padded envelope but I'm hoping they work.
FORD Barn rocks for info and help!
Regards,
Todd
Old 06-17-2019, 04:10 AM   #13
cajunfirehawk
Update;
I was able to remove the donor spare tire cover trim and salvage 6 original 80+ yr old clips! Installed it on my tire cover and they held w/the 6 I have. Until I can find a better replacement trim molding in better condition this one will work.
Regards,
Todd
Old 06-17-2019, 08:05 PM   #14
v8fordman
v8fordman's Avatar
I may have a ring that I can sell. I will have to measure the width as it is still wrapped in protective paper when I had it repaired and polished. I have not looked at them lately as I had some '34's and '36's done years ago. Email me at [email protected] if you are interested.
v8fordman is offline   Reply With Quote
Old 06-18-2019, 04:54 PM   #15
cajunfirehawk
I sent you an email yesterday for this ring if you have it...imagine others did too? PLMK
Regards,
Todd
