07-31-2010, 08:13 PM | #1 |
Paint striping with tape
IS IT POSSIBLE TO STRIP ON THE CAR USING 1/8 TAPE? SAY PAINTING IT THEN PUTTING IT ON TO SAVE MONEY? iF SO WHERE CAN i BUY THE TAPE MAYBE IN COLOR SO i DON'T HAVE TO PAINT? AND WHAT TYPE PAINT IS NEEDED . THANKS '/jOHN
07-31-2010, 08:37 PM | #2 |
Re: Paint striping with tape
ck with a local paint suppy (auto) house in your area. Pinstripe tape (decal) IS available in diff widths/colors. Put a pin stripe on my taurus years ago, changed the look drastically, really dressed it up.
Paul in CT |
07-31-2010, 09:07 PM | #3 |
I used 3M tape for my 30 Coupe. Buckskin tape came very close to the Tacome Creme. It can be a little difficult to make a real small radius like just behind the rear fender on a couple but works well. It has been on there 3 years now with not problems.
07-31-2010, 09:23 PM | #4 |
I use pinstripe tape all the time on late models, works good when done properly.
Use 3M only. |
08-01-2010, 06:12 AM | #5 |
I like Finesse Pinstriping Tape.
It's prespaced with a clear a strip over top. You apply it, pull off the clear strip, paint the lines with One Shot lettering enamel, then pull off the pre-spaced masks. Auto body supply store should have it. Comes in many widths/spacing variations. |
08-01-2010, 09:13 AM | #6 |
I had my 29 standard coupe pin stripped with tape for less than $40.00 at a local body shop. Looks great! John Wing Houston Texas |
08-01-2010, 09:20 PM | #7 | |
