Old 04-26-2019, 01:18 AM   #41
KULTULZ
KULTULZ's Avatar
Default Re: Y Block Valve Springs, Rocker Arms &c
No problem and THANX! for thanking...
KULTULZ is offline   Reply With Quote
Old 04-27-2019, 07:23 PM   #42
briphaeton
I can't find what diameter the rocker shaft should be? I check the 1956 Ford manual.
Thanks , Brian
briphaeton is offline   Reply With Quote
Old 04-27-2019, 08:51 PM   #43
wellcraft17
.781 just measured one of mine
wellcraft17 is online now   Reply With Quote
Old 11-29-2019, 09:07 PM   #44
KULTULZ
KULTULZ's Avatar
Red face Re: Y Block Valve Springs, Rocker Arms &c
Originally Posted by dirtywaterdiver View Post
Anyone know the correct size or part Number for the wave washers on the Rocker Arm assemblies? Need 'em for my 292
https://www.mcmaster.com/wave-washers
Originally Posted by KULTULZ View Post
B8A 6598-A
1.18in OD
.86in ID
.008in Thick
... ... sigh ...
... you gotta wonder ...
I made a mistake. That PN is for an FE. You want -
EAA 6598-A - Spring Washer
The solid washer is -
EAA 6590-A - Washer - Rocker Arm Shaft
Steel - 1.26" O.D. - .81 " I.D. (So this will be the sizing - Size not given in MPC)
I am sincerely sorry. I am having the old lady call the home in the morning to begin processing ...
File Type: jpg Rocker Arm Shaft Assembly- FYB _1B - MPC ILL.jpg (57.2 KB, 3 views)
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
