10-23-2021, 10:58 PM | #1 |
Looking for photo of a stop light switch installed in a 31.
My dad is looking for a photo of a stop light switch installed in a 31 Model A. I would appreciate if anyone had a photo they would be willing to share.
We can find photos of the part isolated, but not installed. |
10-23-2021, 11:26 PM | #2 |
Re: Looking for photo of a stop light switch installed in a 31.
This is the diagram from Service Bulletins. Switch mounts to frame center cross member. Look for 3 holes in line with the brake pedal. 2 of these holes will match the hole pattern on the switch, and center hole is for the plunger to protrude through. The brake pedal to cross shaft has a round flat foot on the end which the switch plunger bumps up against. When the brake pedal is depressed, the plunger can move forward and circuit is closed.
10-24-2021, 10:20 AM | #3 |
The electrical screws are towards running board, I just installed one, twisted and turned it until it fit. Under the car on your back ain't much fun, oh by the way...... I used a stick to push the brake pedal down and hold it away from the switch, found that out after crawling out from under the car umpteenth time
10-24-2021, 06:49 PM | #4 |
Thank you, both.
10-24-2021, 10:25 PM | #5 | |
10-24-2021, 10:28 PM | #6 |
This is the diagram from Service Bulletin as Posted by 40-A Twins |
10-25-2021, 12:15 PM | #7 |
Yes this is the complete book of Service Bulletins https://www.amazon.com/Model-Ford-Se...=UTF8&qid=&sr=
Another helpful guide is the Model A Restoration Guidelines and Judging Standards which is very helpful even if you are not restoring your car for show. Without this book I would have never figured out which wiper motor was correct for my 31 coupe. https://www.mafca.com/cart/index.php?productID=115 |
10-25-2021, 02:12 PM | #8 |
Just piping up to remind everyone that you can get the Service Bulletins as a searchable PDF file. Also nice to be able to zoom in on the text, for those of us with older eyes.
10-25-2021, 04:25 PM | #9 |
10-25-2021, 04:35 PM | #10 |
Here are pics of the switch on my 1930
10-25-2021, 05:51 PM | #11 | |
https://www.ecklers.com/service-bull...7-68631-1.html |
