03-14-2024, 11:08 AM | #1 |
Model "B" Engine Differences
In 1932 an “Improved 4-Cylinder Engine” was introduced for cars and trucks, and it remained in vehicle production through 1934. Buyers had a choice of the Improved 4-Cylinder engine or the new V8. The “Improved 4-Cylinder Engine” is designated as the Model “B” Engine, Part Number B-6005. The question arises, “What are the differences in the Model “B” engine versus the Model “A” 4-cylinder engine?” The following is an overview of the changes:
· Pressurized oil supply to the main and camshaft bearings; · Larger diameter main and connecting rod bearings; · Larger venturi carburetor with a power jet & transversely mounted float; · Carburetor oil bath air filters B-9625 & BB-9625 available thru service; · Intake manifold with larger internal diameter; · Slightly higher compression ratio cylinder head; · Lighter flywheel; · Improved camshaft; · Front engine cover with timing pin offset so timing is 19 Degrees BFTDC; · Distributor with an ignition timing adjustment for gasoline quality (octane); · Distributor with centrifugal timing advance; · Distributor cam with smoother transitions to lobes; · Distributor body with 1/8” decreased notch height; · Mechanical fuel pump; · Larger water pump impeller; · 3-bolt water pump attachment; · C4 Champion Spark Plugs with 0.030” gap; · Larger diameter B-6763-B oil filler pipe; · Thin-wall cylinder block casting technology; · Different exhaust manifold shape; · Oil pump with undercut shaft for increased oil flow; · SAE oils with a 1000-mile engine oil change interval; · Elimination of oil return tube; · Valve chamber with pressurized galley & larger valve cover; · Oil pan with flywheel housing attached & outward indentations in its sides to clear connecting rods.
Bob Bidonde Last edited by Bob Bidonde; 03-15-2024 at 10:04 AM. |
03-14-2024, 11:36 AM | #2 |
Re: Model "B" Engine Differences
· Front engine cover with timing pin offset so timing is 190 BFTDC;
03-14-2024, 11:48 AM | #3 |
03-15-2024, 10:06 AM | #4 |
Bob Bidonde |
