05-18-2023, 07:35 AM | #21 |
Re: Safe Way to Check Valve-Head Clearance?
Great job Zig. I'm trying to find a shope near me to Braze fill smoe part of the combustion chamber. I have a way to move the spark plug, and angle milling is pretty common today. The results would be a 258 with 9:1 cR and better breathing thhan any aftermarket head at 1/2 the price. Thus was a common modification to a stock head back in the 50s&60s the Danbery rules said NO aftermarket heads. This was to reduce the cost of racing. After this rule was eliminated, we went to the aftermarket and found the these heads limited RPN power. I think the stock heads have some class.
Gramps |
05-18-2023, 08:24 AM | #22 |
Thanks. I’m just a novice, but it is websites like this and folks like you that are willing to share their knowledge that has made this an incredible journey. I agree that raising the CR will be important in raising hp. I was actually surprised to see the sparkplug indentation over the exhaust valve. You certainly wouldn’t expect that looking at the head. I think with my setup (0.060” with the stk 3.75” stroke, and the C7RA stk heads), my CR is a measly 7.14. Good enough for my purposes, but certainly not where you want it to be if more power is your goal.
05-18-2023, 01:58 PM | #23 | |
When it comes to spark plugs especially with the NGK brand which I prefer over all others I always add one more spark plug washer. This helps reduce the possibility of the valve coming in contact with the plug electrode if I miss a shift. Funny things happen when the revs are getting near 6 grand valves like to float. Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
05-18-2023, 07:07 PM | #24 |
Ol'Ron>>>angle milling is pretty common today>>>
Still worry a bit about studs & bolts without enlarging the holes. I'd rather mill flat & install an angled gasket with an angle of my choosing. 8^) |
05-19-2023, 06:17 AM | #25 | |
05-20-2023, 01:28 PM | #26 |
Piston to head clearance: Given that you're at .073 or so, if it was my engine, I'd have the heads shaved to reduce the clearance to 0.045 (minimum for all areas over the piston crown). This is the final quench dimension - with the head gasket in place. Valve to Head Clearance: As you noted, due to the valve angle, they are closest to the head at the very tops. So, if you mill the heads .030, then depending on your final measurements, you may need to do the manual clearance work on the heads for valve clearances at the top of the chambers. The amount you have to clearance will usually be different on one head versus the other (again, due to valve angles the valve heights are different as they relate to the deck). Manual Head Clearance Work - for Tops of Valves: I'd use a carbide tool to rework the TOPs of the chambers (the eyebrow area) to give myself about .060 over the tops of the valves (to the head). If you need any examples of the type of bits I use, just ask. I can't remember if your heads are aluminum or cast-iron (while writing this), so the types of rotary files/bits to use will differ depending on the head material. |
