12-09-2018, 06:49 PM | #1 |
Boiled Over In Winter.
Well the heat gauge works on the Merc anyway. I didn't believe it was that hot. Checked the top hoses several times with my hand and they were not all that hot yet the gauge read nearly to the last dot. Ambient temp was around +20F at most so I had the rad covered to warm it up properly. Got a little bit stuck with the bald tires when I stopped to take a picture. In the process of rocking back and forth I lost sight of the guage and next thing steam came from under the hood. A stream of anti freeze was spraying from a weak spot in the tank over the engine, hitting the hood and soaking the coil wire to the dist. So now I know, trust the heat gauge.
https://www.youtube.com/user/roosty6/videos |
12-09-2018, 11:13 PM | #2 |
Re: Boiled Over In Winter.
Ralph, love your pictures!!! That's a beautiful winter sunset or is it a sunrise??!!! Does that hay bale stay out all winter??
12-09-2018, 11:41 PM | #3 |
When I was growing in NE Washington in the 50's, my Gpa never let us cover the radiators of any equipment as long as there was antifreeze in it. He said he saw too many engines ruined by overheating. He said let the thermostats do their job. Hope yours is ok.
I too love your photos!! |
12-09-2018, 11:49 PM | #4 |
That is sundown. I'm not a morning person :-). Covered radiators are pretty much compulsory here in winter on older vehicles. The Merc has no thermostats. This would not have been a problem today if I had just believed my heat gauge and uncovered the rad partially. . It really was that hot. Anyway, now I know where the radiator needs soldering. :-( Got some video of the day's driving here.
https://youtu.be/KO6QzVe_xGY
12-09-2018, 11:49 PM | #5 |
Yes, I hope your merc is ok! I always feel funny blocking the air flow, I had a radiator that was plugged up and boy my engine sure heated up quick! Also a steamer!
12-10-2018, 12:00 AM | #6 |
12-10-2018, 01:57 AM | #7 |
Lovely picture of the Mercury at sunset. Thanks for sharing. |
12-10-2018, 03:14 AM | #8 |
I had a 1970 ford truck that overheated here in Alaska at 25 below once. If something’s wrong, doesn’t matter how cold it is.
12-10-2018, 09:49 AM | #9 |
You have either
1--- clogged radiator tubes 2--- wrong fan, pulley or belt slips 3--- compression leak 4--- water pumps not suppling enough flow G.M.
www.fordcollector.com |
12-10-2018, 10:01 AM | #10 |
12-10-2018, 10:14 AM | #11 |
You got it!
This is the first time the engine has boiled in the almost 4 years I have driven it. I wanted to get the temp up to normal on this cool winter day and its not easy with no thermostats. I've used the covered rad method many times and its never a problem as long as I watch (and believe) the heat gauge. Those top hoses just did not feel that hot to my hands so I left the rad covered. Now I know. The top dot on the heat gauge really is the boiling point.
12-10-2018, 12:18 PM | #12 |
Beautiful picture. Yep, cardboard in front of radiator. Adjust coverage as indicated by by temp gauge. Mike
12-10-2018, 12:50 PM | #13 |
Ralph, right up your alley, had a John Deere B tractor once that had lever operated shutters in front of the radiator.....at least I think I remember it being that way!!
12-10-2018, 04:00 PM | #14 |
why no stats ? jack
12-10-2018, 04:08 PM | #15 |
You always manage to find an adventure riding around that farm!!!...for the entertainment of the rest of us!!!... Great photo as always. I drive an ‘81 F100 with a cooling system in good shape. I end up putting card board over about half of the radiator when it gets real cold. Just to get a little more heat out of the old truck. Happy Holidays to you and yours!!!
..... Mark
12-10-2018, 07:07 PM | #16 | |
Shoeboxjack, the guy that rebuilt the engine about 35 years ago tells me it didn't have thermostats. The popular belief at the time was that they restricted the flow of coolant and would make it run hot in summer. . Mark, I run my 81 Sierra Classic with a winter front ever since I bought it in 86.
12-10-2018, 08:55 PM | #17 |
So in a previous thread a while back, a guy mentioned something, I really didn't think about... the mix. Slushy bad mix of anti-freeze... will inhibit flow. I guess now in the north I need one of them turkey basters with multi colored balls. No idea how they work???
of course a wayyyy cool picture! always |
12-11-2018, 12:02 AM | #18 | |
It was the cat food bag over the radiator that did it.
12-11-2018, 12:14 AM | #19 | |
cat's can kill mice and rats, terriers are way better at it. Your pictures are the best! When is the coffee table coming out Ralph? |
12-11-2018, 07:27 AM | #20 |
Making lemonade out of a pile of lemons. Great picture, made me shiver. Of course here in Arizona it will be 65 with lows in the 40's today. Us locals as. Chap
