09-14-2015, 12:51 PM | #1 |
Flsthead tachometer suggestions
I just returned a SW Wings tach that I could not get to register correctly at idle.
I've read a couple of blogs from guys having problems with today's tachs with similar problems. I'm hoping to pick your brain as to a tach that has worked well on your flathead. While function is a priority, second would be to keep the old school look. I need a column mount and I have converted to 12 neg ground. The old Suns use to be flawless, maybe I need to find a good used one.....
Tim Downtown, Ca |
09-14-2015, 01:45 PM | #2 |
Re: Flsthead tachometer suggestions
Although mine is 6 volt, my Westach has been great. Here is their website: http://www.westach.com/
If it aint broke, don't fix it! |
09-14-2015, 02:02 PM | #3 |
i have the old moon eye 12 volts works great old school looks
09-18-2015, 08:55 PM | #4 |
09-14-2015, 03:10 PM | #5 |
I found a nice 500k Sun "Football" tach on eBay, and had it converted to solid state by Williamson's Instruments. Vintage look and works great.
09-14-2015, 04:38 PM | #6 |
I had to buy the control module for it from studebaker intl, but it works good and definitely looks as old as the rest of my gauges. Sorry though, it fits in the dash. But it is an option. |
09-14-2015, 07:50 PM | #7 |
My new SW tach and electronic speedo would both bounce wildly at idle. When I switched from dual points to Pertronics and to GPS speedo the problem went away. Can't say which change did it.
09-15-2015, 12:20 PM | #8 |
You might try Classic Instruments. 1 800 668 9216 They can make custom gages. Get the look you want.
09-15-2015, 12:40 PM | #9 |
i put a sun football tach on my merc with a transmitter under the hood with batterys in it. works perfect its 6 volt. found it on ebay a few years ago.they were nos. i have the same set up on my 67 ford ranchero.
09-15-2015, 03:45 PM | #10 |
I think I have one down in my basement. It belonged to one of my brothers. It takes a battery that he said was no longer available. |
09-15-2015, 04:22 PM | #11 |
Battery isnt the problem...that the batteries was left in them and corroded to pieces is.
Its original equiped with a 1.3v mercury battery. Sticking in a regular 1.5v AA cell makes the reading way off. There are rechargeables that is about right or go with a voltage regulated source. Best is a solidstate conversion. |
09-15-2015, 05:04 PM | #12 |
I found some after market batt. Made for the trasmitter on ebay a few years ago on ebay they were $25.00 a pair.and they are still working.
09-16-2015, 07:58 PM | #13 |
Yes he said it was a mercury battery and I think the old batteries were removed, I might dig it out and take a look at it.
