#1 |
Steve, when you PM-ed me, you did not give me an e-mail address to send these too, ...and I do not think I can attach photos in a PM. Here is some various pictures of a 1931 Coupe top for you to look at. Hopefully this is what you wanted to see. If you need anything additional, let me know...
#2 |
#3 |
Brent: Thanks for the pictures. I will be putting a top on my '31 Coupe when the weather warms up. Richard Lorenz
#4 |
do you put any sealer under the top material to stop water leaks or does the ridge keep the water out im going to be putting my top on in a few days in a heated garage with a heat lamp to warm the material
#5 | |
Also, from experience I can tell you that old, hard topwood over time does not hold the mouldings tightly ...which after some vibration & flexing, the moulding begins to loosen (which in turn allows water to penetrate). I honestly think that back in the day, the Ford intent was to be much better with an affixed roof however they still had leakage issue after awhile. |
