09-07-2014, 07:49 PM | #11 |
Re: Yes, they are still out there NUMBER 2
Last couple of days as I found time I have pressure washed, diesel fuel cleaned with brush, Purple power, water and wire brush on drill. I cleanded pounds of solid grease off the rear end of the 39LZ. This is what I came up with, very red. QUESTION for today?? I cleaned up old solid froze grease from fitting in the middle of torque tube, the fitting sticks out about 3/4" and now leaks oil, why is it leaking oil, does the fitting that lubes mid shaft bearing need repaired??? Any info appreciated.
. Before photo of rear end . . . After clean up . . . Grease Fitting in Torque Tube . |
