Old 04-03-2016, 02:30 PM   #1
Roger/Sacramento
Roger/Sacramento's Avatar
Default T5 transmission noise
I have an Old World out of an S10 pickup. Had the tranny opened up and cleaned and checked by a shop. Installed the tranny and it worked fine but, made a whining noise in 3,4,5 gears. Talked with the shop and they said they never checked the bearings because they have to be broken down to check. Took the tranny out and had the shop replace the bearings. The originals were only slightly worn. After reinstallation the noise is still there. What experience has others had ?
KIM KARDASHIAN ISN'T FLAT, BUT MY MOTOR IS.....
http://s818.photobucket.com/home/roglehr/index
Roger/Sacramento is offline   Reply With Quote
Old 04-03-2016, 04:43 PM   #2
TomT/Williamsburg
TomT/Williamsburg's Avatar
Default Re: T5 transmission noise
I am no tranny expert but ....
I usually get a rebuild kit and unless what is in the tranny is near perfect, I change out all of the synchros and that goes for every part in the kit. Some trannys, like my T5Z, are so good practically nothing needed changing. Others it was everything in the kit and even some gears.
I would check on the Hamb for flat Ernie - he has a ton of T5 info and perhaps post your question there. You will probably get a more specific response from that forum vs here .....
TomT/Williamsburg is offline   Reply With Quote
Old 04-03-2016, 04:58 PM   #3
prpmmp
What trans fluid are you using? I had a NWC T5 that had ATF in it,switched to 20-50 Mobil One and it was a lot quieter. Pete
prpmmp is offline   Reply With Quote
Old 04-03-2016, 06:00 PM   #4
JSeery
JSeery's Avatar
Think you can do that on a NWC, but not a WC.
Old 04-03-2016, 06:18 PM   #5
prpmmp
Yes!! I believe you are right(something about the synchros)?Pete
Old 04-03-2016, 09:19 PM   #6
Roger/Sacramento
I am using Amsoil transmission fluid
Old 04-03-2016, 10:53 PM   #7
4t8v8
I completely rebuilt my NWC T5 even though it looked good. Carefully set the end play and bearing pre load and have used Royal Purple Max Gear in it for a number of years. Shifts smooth and no noise at all. The T5's are easy to work on.
4t8v8 is offline   Reply With Quote
Old 04-04-2016, 08:46 AM   #8
Flat Ernie
Flat Ernie's Avatar
I DO NOT recommend anyone use engine oil in a T5. It doesn't have the correct additives for use in a transmission. There are special shear additives that are absent in motor oil. While folks have done it and gotten away with it, it is more because these old hot rods and Fords don't see near the mileage of daily drivers.
I run synthetic ATF in all T5 - WC & NWC. I find the GM synchromesh too thick and the gear oil originally called for in early T5 to be WAY too thick (the old Ford oil translates to a 70W gear oil). It doesn't hurt anything, but it makes them sluggish to shift, especially when cold.
I suspect end play. End play is the easiest adjustment one can do on a T5, although you need to pull the top & tail off to do it. I set mine to the tighter end of the tolerance.
Is your whine less in 4th at all? Generally, 4th has the least noise of any gear, but if it's noticeably & significantly quieter than the other gears, it is indicative of a bad input bearing...although too much end play can be almost as bad. If you have way too much end play, that will result in worn/broken synchros and dogs on the gears.
Daddy always said, "If yer gonna be dumb, you gotta be tough" and I'm one tough sumbitch!
T5 Tech
Flat Ernie is offline   Reply With Quote
Old 04-04-2016, 10:39 AM   #9
Mike51Merc
Mike51Merc's Avatar
World Class have carbon fiber synchros that can delaminate unless ATF is used.
Mike51Merc is offline   Reply With Quote
Old 04-04-2016, 11:20 AM   #10
Flat32
I have a NWC T5 in my coupe and I did a fair amount of research before buying it. I read about the input bearing and shaft needing almost dead nuts alignment to avoid premature wear and failure. Much less tolerant of mis-alignment than the typical old Ford transmissions.
The registration hole in whatever bell housing or adapter must be a certain size, be concentric with the crankshaft and the bell housing to trans mount face true perpendicular to within a certain spec. Another thing to watch out for when adapting is the pilot end of the input shaft not binding lengthwise.
Flat32
Flat32 is offline   Reply With Quote
Old 04-04-2016, 05:00 PM   #11
Roger/Sacramento
The whine is in 3.4 and 5 equally. No noise in 1 and 2.
Old 04-04-2016, 05:42 PM   #12
Flat Ernie
Flat Ernie's Avatar
Well, it's more likely that it's bearings if you have noise in certain gears, but not others, especially if 4th is noisy. 4th gear goes straight through and all other gears go through the countershaft putting side loads on all bearings. Any slop shows up as noise. This is why end play is so critical in these transmissions (and most transmissions).
End play may still quiet it all down, but sounds like it may be best to simply go through it and put new bearings in throughout.
T5 Tech
Old 04-05-2016, 12:05 PM   #13
Roger/Sacramento
As per my initial post.....the shop replaced all the bearings.
Old 04-05-2016, 08:45 PM   #14
Flat Ernie
Flat Ernie's Avatar
Is there any vibration with the noise? Is it harder to shift into any gears?
End play may still be the culprit...
T5 Tech
Old 04-05-2016, 10:54 PM   #15
Roger/Sacramento
No vibration and shifting is easy. The noise is only when under load. No noise when I let up on the gas. Why is noise only in top three gears ? Not sure what is meant by endplay.
Old 04-06-2016, 07:16 AM   #16
Adam/Mill Valley CA
Adam/Mill Valley CA's Avatar
Roger, I had the exact same problem with my T5 which my son and I installed in his '65 Mustang. It was a non-World Class rebuilt completely by an excellent racing shop located at Sears Point. I brought the tranny back to the rebuilder, he said the only thing that he could figure was an improperly machined input shaft. He went through it again (gratis, of course), replaced that with a different (new) input shaft,and it has been perfect ever since-about 10,000 miles on it now. We use synthetic ATF.
Adam
1936 pickup, stock, black
1965 Mustang coupe 289/4bbl, black/red
1971 Alfa Romeo GTV 1750 coupe, dark red/tan
1970 911E 2.2 litre dark blue/black
1968 BMW R50/2 US, black (m'cycle)
1967 Triumph TR6R , sea foam/cream (m'cycle)
2022 Royal Enfield Interceptor 650 red (m'cycle)
1974 Honda CB750 red (m'cycle)
2000 Kawasaki W650 blue/silver (m'cycle)
Adam/Mill Valley CA is offline   Reply With Quote
Old 04-06-2016, 04:32 PM   #17
jack orchard
Is tailshaft bushing nice and tight? I is very important that it be snug. If it is sloppy, it will allow the mainshaft to flop around in relation to the input shaft. Also, when setting total end play, a yoke should be used to center the output shaft. Just thoughts.,...jack
Proud FNG
We fixem cars. Heap Good!
jack orchard is offline   Reply With Quote
Old 04-06-2016, 07:46 PM   #18
Flat Ernie
Flat Ernie's Avatar
Why is noise only in top three gears ? Not sure what is meant by endplay.[/COLOR][/SIZE][/FONT]
I've never seen one that was only noise in 3,4,5...
End play is the total movement front-to-back within the case. It is set by shimming the input bearing under the input collar/bearing retainer.
T5 Tech
