06-13-2019, 06:24 PM | #1 |
rear view cameras
As you that drive a '40 coupe know, you can't see squat out the back. Anyone have ideas that have worked for you ? I was thinking of a rear view camera, but the installer says there is nothing out there for a 6 volt + ground system. Thank you Fordbarners.
06-13-2019, 06:25 PM | #2 |
Re: rear view cameras
A "converter" that changes 6V to 12V.
Looking into something so I can run my tach. Paul in CT |
06-13-2019, 08:37 PM | #3 | |
06-13-2019, 10:44 PM | #4 |
You can get a step up converter board on Ebay for around $5 shipping included. Here is an example.
https://www.ebay.ca/itm/DC-DC-Digita...item4d8fd6304a I use them in all my antiques and they work pretty good although you end up replacing them every so often so buy an extra. I always put in a cigarette lighter outlet which is really cheap as well. That way you can charge your phone etc. on tours and run a dash camera. Just disguise it or put it in a hidden spot. |
06-13-2019, 06:34 PM | #5 |
They do make a converter that will give you 12 volts to run the camera.
06-13-2019, 07:35 PM | #6 |
06-13-2019, 07:40 PM | #7 |
I have seen a Bluetooth battery powered camera that mounts to your license plate someplace. Don’t know how often it might need charging?
Sent from my iPad using Tapatalk |
06-13-2019, 08:01 PM | #8 |
This is one that was on Amazon.
06-14-2019, 01:43 AM | #9 |
The cheap converters are usually lacking 2 things enough heatsinking and an isolation transformer.
The lack of the transformer means that they will be 12v Pos ground...so even if you get the cables right on a modern radio as soon as the metal case hits the dash sparks start flying and it shorts out...since - is now hitting the grounded + dash... I use them to both for Dropping and boosting just be aware of what you are buying...the ones with isolation between input-output has a higher parts count and cost more... |
