05-29-2016, 11:38 AM | #1 |
early offy intake
Picked this up this weekend. Never seen one like it. What can you fellas tell me about it? The edge of the intake is 1/2 inch thick. Thanks Bill
05-29-2016, 06:56 PM | #2 |
Re: early offy intake
I'm no flathead expert, but looks like someone shaved of the generator mount off and made a crankcase breather out of that area. Probably for a race car without a charging system ?
Sal |
05-29-2016, 07:15 PM | #3 |
I agree with Sal. I don't have a manifold or catalog to compare it with, but that breather sure didn't come from Offenhauser like that, though the breather itself might have.
05-29-2016, 10:18 PM | #4 |
I disagree- it indeed did come like that. I have seen others.
05-29-2016, 11:00 PM | #5 |
05-30-2016, 12:02 AM | #6 |
05-30-2016, 12:28 AM | #7 |
Ya' learn something every day. Although I find a "racing model" with heat to be a bit odd. The way the breather is attached looks pretty professional. I think the cheesy blue paint affected my judgement.
05-30-2016, 06:08 AM | #8 |
05-30-2016, 07:32 AM | #9 |
Bill
That was Offy's answer to the Edelbrock super dual, They Made two versions, one was an inch higher, and is no longer made. This may bt that unit. I used one on the Bville engine converted to two 2GC's. Yes, I think someone installed a pan breather on the front. Good idea. Probably used an off set gen bracket. |
05-30-2016, 10:25 AM | #10 |
99 percent sure the breather is original. Everything looks to perfect a job. I did a quick low pressure glass bead to clean up. From bottom of intake to the top of carb mount is 4-1/2 ". Same as my 8ba offy.
05-30-2016, 10:46 AM | #11 | |
That's what confused me too. I agree that it's an early manifold for racing, since the experts chimed in, but why would it have the exhaust crossover to heat the manifold ? Unless it's plugged internally and Offy just modified a street manifold to make this one. Sal |
05-30-2016, 12:34 PM | #12 |
I have a photo of the Bville intake, I'll look for it. I still think someone just bolted it on.
05-30-2016, 02:58 PM | #13 |
It it doubtful to me that the front breather was 'factory original'. It would require additional machining steps that I don't think they'd like to do -- or they would have cast that area with the breather cavity and a boss on the outside. Now this is just a wild-ass guess/opinion - not based on any knowledge of any kind! (Like most opinions I guess )
05-30-2016, 02:59 PM | #14 |
But regardless of how it came to be . . . it is still cool!
05-30-2016, 07:03 PM | #15 | |
05-31-2016, 08:37 AM | #16 |
It would be nice to see pics of others like this for comparison.
