07-13-2018, 04:20 PM | #1 |
How to lower the A.
I know there was a thread about this however a search turns up everything else but.
In searching for a 1932-1934 front axle I find them to be made of unobtainium. I have found a '37 front axle. However the spring perches are much further apart than the A and '32-'34. My question is if I fit it with Model A perches and a '37 spring will it work on my A? Secondly what would I do for the wishbone as the A isn't wide enough and widening it will shorten it. Should I toss this idea and continue my search for the '32-'34 axle? TIA for your help.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
07-13-2018, 05:10 PM | #2 |
Re: How to lower the A.
you can go pretty low by reshaping the springs
07-13-2018, 05:20 PM | #3 |
Sounds like you want to do it on the cheap., or you would just buy a dropped axle and bolt it in.
You can easily re-arch the front main spring leaf the opposite way in a shop press to make it a reversed eye, and straighten the other leaves a bit to also lower the whole spring. Will gain you a 2 inch drop easy. |
07-13-2018, 09:44 PM | #4 | |
07-13-2018, 05:20 PM | #5 |
07-13-2018, 05:24 PM | #6 |
07-13-2018, 07:45 PM | #7 |
i got a 4 in dropped axle in my car
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
07-14-2018, 12:50 AM | #8 |
Once again 32-36 are the same part number
B3020. 37 is part number 78-3010 Interestingly enough there is a larger 32 axle, but it’s not listed in the orange 28 to 37 parts book. |
07-14-2018, 04:44 AM | #9 |
These are great answers and on the HAMB forum (sister to this one) they specialize in these kinds of mods. https://www.jalopyjournal.com/forum/...l-hot-rods.57/
07-15-2018, 02:23 PM | #10 | |
07-15-2018, 07:40 PM | #11 |
Sure it does, look for the tab with the picture of a magnifying glass
07-15-2018, 08:04 PM | #12 |
Thanks for pointing that out. I was looking for the word SEARCH.
07-14-2018, 08:18 AM | #13 |
Google "fordbarn model a ford lower front axle"
07-14-2018, 10:07 AM | #14 |
Chris
I may be able to help PM sent Jim |
07-14-2018, 10:29 AM | #15 |
I’ve bought 3 of those axles off of eBay. They come up every once in awhile. Keep looking,
They only hard one to get is the early “heavy” 1932 axle. |
07-14-2018, 10:32 AM | #16 |
According to David G there is NOT a heavy axle. FWIW
Paul in CT |
07-14-2018, 11:16 AM | #17 |
'32-'34 have the same contour, '35 and later have the wider spring perches as you noted. '32 had both the std. and heavy axles. Good luck.
07-16-2018, 12:36 AM | #18 |
1932-36 axles are the same dimensionally (same widths and hole locations) and are totally interchangeable (as someone noted earlier). There was only ONE 1932 axle and it has a thicker profile, thus the often used "heavy" nomenclature. The 1933 axles (at least some of them) have a thicker profile in the center section between the wishbone holes. 1934-36 axles are identical - the difference in spring mounting for 1935-36 is a factor of the wishbones only. All these axles are 1/4" thinner at the wishbone attaching holes and a spacer must be used when using them in conjunction with Model A wishbones. All but the 1932 axles are reasonably priced and should be easy located.
07-15-2018, 02:51 PM | #19 |
Don't need a search function on HAMB try this in your google search box;
hamb; dropped axle I just tried it and a whole bunch of links to HAMB and dropped axle. Works with fordbarn; xxx too.
I know the voices aren't real but damn they have some good ideas! |
07-15-2018, 03:51 PM | #20 |
Thank you. But I am looking for a stock axle, not dropped.
