Old 03-26-2016, 05:17 PM   #1
old31
Default Help for manifold heater 31 deluxe roadster
I am looking for a manifold heater and don't know anything about them.
Do they work?
Has anyone tried the ones that Snyders or the others sell?
http://www.snydersantiqueauto.com/manifold-heater
https://www.brattons.com/auto-lite-manifold-heater.html
old31 is offline   Reply With Quote
Old 03-26-2016, 05:24 PM   #2
DougVieyra
DougVieyra's Avatar
Default Re: Help for manifold heater 31 deluxe roadster
Yes, the do work, and quite well.
For an open car, only the passenger will get the benefit unless you install your side-curtains.
Some people are concerned with the possibility of an exhaust leak, which may send in fumes to the interor compartment. So that would be something to watch out for.
Additionally, especially for those who have concerns with leaking exhaust, there is also available now at the Parts Houses, a Hot Water version of the car heater.
There were a plethora of makers of the Exhaust Manifold Heaters during the 1930's, so a great many are still around. You may prefer to get one of those, via the Classifieds of various Model A organizations, including FORD BARN.
I am sure you know you will have to drill a big hole in your firewall to get the heat into your interior compartment.
DougVieyra is offline   Reply With Quote
Old 03-26-2016, 05:28 PM   #3
SSsssteamer
SSsssteamer's Avatar
I have Manifold heaters on four of our six model A Fords. Excellent heat, and right away too. Three of the A's use the Autolight that has the two bolts on top. The Phaeton uses the modern one like what is sold from Snyders and Brattons. It works just as well as the Autolight manifold heater. The adjustable heater door is a requirement. In the middle of the winter, the heater can get so hot in the front seat, that it can run you out of the car. My 70 year old wife refuses to ride in our model A Fords unless I have a working manifold heater installed. "Don't leave home without one"
SSsssteamer is offline   Reply With Quote
Old 03-26-2016, 05:32 PM   #4
SSsssteamer
In the middle of the winter, our phaeton's heater works best with the side curtain on. If the curtains are not on, then lay a blanket across your laps and then both the driver and passenger are toasty. The Phaeton's back seat passengers go without the heater when the side curtains are off.
Old 03-26-2016, 07:16 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
If you already have a heater hole in the firewall, then a manifold heater might be my choice, but if there is NO hole there, I sure wouldn't cut one because the hot water heater will do a great job and you can drill a couple hose holes in the repro wood floorboards.
Old 03-26-2016, 08:39 PM   #6
MikeK
MikeK's Avatar
Not all manifold heaters require a hole through the firewall. Here's one from my collection that feeds under the firewall and through the floorboard. There are several others that also feed through the replaceable wood rather than requiring a hole in the steel.
MikeK is offline   Reply With Quote
Old 03-26-2016, 09:07 PM   #7
Charlie Stephens
Also note that the location of the hole may be different for different makes of heaters.
Charlie Stephens
Old 03-27-2016, 07:25 AM   #8
old31
I do not have a hole in the firewall, and will take a look at the hot water heaters.
Old 03-27-2016, 07:45 AM   #9
Tom Wesenberg
Actually I wouldn't mind having a manifold heater like Mike just showed, but I've never found one at a swap meet. I just hate to see holes cut in good firewalls.
Old 03-27-2016, 08:06 AM   #10
Terry, NJ
Terry, NJ's Avatar
I don't know about the Snyder's product, But I have manifold heaters on all my cars. It won't shoot out heat like a blast furnace, but it will warm up the cabin and it helps with keeping the windshield clear. I recommend them
Terry
Do they work?
Old 03-27-2016, 09:04 AM   #11
Ray in La Mesa
MikeK, I have two like the one you picture but do not have the darker floor mounted parts. Could you post a clearer photo of the that please? By the way, they are for sale as we don't have any need for them in San Diego area.
Ray in La Mesa is offline   Reply With Quote
Old 03-27-2016, 11:19 AM   #12
taffrail
taffrail's Avatar
I agree with not cutting the fire wall. Two of mine had holes with out heaters. I searched for pictures to find the correct manifold. One ended up to be an Otwell, the other an Atlas. Much easer to bolt on a manifold than correctly patch a hole. Ebay has plenty of them. Great heat for nice day cruises in the northeast.
taffrail is offline   Reply With Quote
Old 03-27-2016, 12:42 PM   #13
Fred S
Fred S's Avatar
In the winter, I carry a small carbon monoxide detector on my package tray.
Fred S is offline   Reply With Quote
Old 04-03-2016, 02:09 PM   #14
old31
Follow up:
I purchased and installed the heater from Snyders. I am pleasantly surprised with the heat that it throws.
My wife said that her feet and legs feel like they died and went to heaven. And that was with no side curtains, 34 degrees and cloudy!
Old 04-03-2016, 05:10 PM   #15
JohnLaVoy
JohnLaVoy's Avatar
I have been researching the manifold heaters for an article I'm working on, there were ones that actually had a blower fan with them. That would be nice for the ones that had the vent in the back seat!
JohnLaVoy is offline   Reply With Quote
Old 04-04-2016, 10:46 AM   #16
old31
Do you have any photos of the heaters with the fans?
Old 04-04-2016, 03:52 PM   #17
JohnLaVoy
JohnLaVoy's Avatar
Here is an ad I found for one. There will be a lot more in the Fall Model A Times.
Old 04-04-2016, 05:33 PM   #18
ed thibodeau
On my Otwell heater I put a cover plate on the front opening in the summer. And when its down near 0* I put a sheet metal large home made funnel on the front so its just clears the fan and it heats me out of the pickup cab and have to roll down the window a bit. I think that the A is so drafty that carbon monoxide could not be a problem unless you are running with out an exhaust system
ed thibodeau is offline   Reply With Quote
Old 04-04-2016, 05:59 PM   #19
old31
Thanks.
Old 04-22-2016, 09:55 AM   #20
old31
Thought that you might want to see photos of the heater that I installed. Really not fun drilling the 2 and 1/8 inch hole in the firewall.
After 200 miles it is still working great.
