01-17-2016, 02:32 AM | #1 |
41 bumpers
I have bought a super deluxe bumper but when I put it next to the bumper I already have it does not have the ford script in the middle. Is this a sedan bumper.Thanks
01-17-2016, 05:41 AM | #2 |
Re: 41 bumpers
Deuce.....I bought one for the rear of my '40. It had the FORD script and was told that it came from the cheaper priced model Ford at the time. The higher priced Ford's did not come with the script. That's all I know except it does look good !
Mike |
01-17-2016, 06:05 AM | #3 |
Re: 41 bumpers
This 1941 Ford Fordor Sedan was imported from South africa into Australia a few years ago. It appears that the original Tail Lights have been replaced with units from a Volkswagen or similar. However, this car has the more fancy Bumpers, and if you look closely, you can see that the rear bumper has the Ford Script. This is the only 1941 Ford Fordor Sedan that I know of. There may be others, but I am not aware of any. They are rare over here. |
01-17-2016, 06:21 AM | #4 |
Re: 41 bumpers
This 1941 Ford Fordor Sedan was spotted back in the Sixties. Note the Ford script in the rear Bumper. This was the only 1941 Ford Sedan that I can recall seeing, even back then when this era of cars were in common use. 1941 Fords are just about non existent in Australia. There are a few Utes, that were made from Sedans for military use, plus a couple of Woodys that were used in World War II. In recent years, a few Tudor Sedans and Coupes have been imported. |
01-17-2016, 06:28 AM | #5 |
Re: 41 bumpers
This is how the 1941 Ford Sedan in the above pictures finished up. These photos were taken in 1989 when the Wrecking Yard was closing down, as the land had been purchased for a housing estate. The Scrappies had a field day at this yard which was full of cars from the thirties to the sixties. |
01-17-2016, 07:33 AM | #6 |
Re: 41 bumpers
01-17-2016, 02:09 PM | #7 |
Re: 41 bumpers
Seeing what happened to that 41 is sad, so much more so seeing what it was.
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. " |
01-17-2016, 11:47 PM | #8 |
Re: 41 bumpers
My '41 S/D Fordor has script rear bumper.
01-18-2016, 12:22 AM | #9 |
Re: 41 bumpers
What about the front bumper does that have the ford script in the middle
01-18-2016, 01:27 AM | #10 | |
Re: 41 bumpers
GB
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" |
01-18-2016, 01:54 AM | #11 | |
Re: 41 bumpers
The front bumper gets a license plate, no script. My 41 has script rear and license plate center mounted front. Only 41 woodies came with no script front and rear, all others get ONE script bumper. . |
01-18-2016, 02:01 AM | #12 |
Re: 41 bumpers
41 Super Deluxe front bumper locates the license plate to center mount onto the bumper itself. Holes were factory punched for super deluxe front bumper license plate brackets and hardware. 41 Deluxe front bumper locates license plate bracket off of the passenger side bumper arm more or less covering part of the passenger grille insert. It was common to see 41 super deluxe with incorrect 41 deluxe non-ribbed) bumper after accident/replacement. It was also common to see Super Deluxe front bumpers missing license plate hardware and trim. jmho. On certain woody and wagons, the rear bumper was also void of script irregardless of deluxe or super deluxe. The tailgate of woody wagons usually would accommodate the spare tire. in which case, the bumper was clearanced in the center top to allow for the tailgate with tire to lower/open without damage or interference to tire/rim/trim rings etc. I have also seen wagons with spare tire mounted inside rear of wagon/compartment -possibly to deter theft, but I can't recall whether this was on 41's or later 42-48 wagons/woodies. Certainly in later models, the choice was optional. . Last edited by moefuzz; 01-18-2016 at 02:47 AM. |
01-18-2016, 03:37 AM | #13 |
Re: 41 bumpers
Just for the sake of completeness, A guy hould probably also mention the very rare painted (no chrome) bumpers both front and rear. Black out bumpers were available as both ribbed (super deluxe) and non-ribbed for WWll, whatever was handy was put into war production. Interestingly enough, there were more than a few 'black out' 41 Fords driving around Canada during and after the war. I seem to remember having a bunch of steel - drab painted trim mixed in with a train load of 40 and 41-48 ford parts many years ago. I don't recall whether it was stainless and painted over trim or just painted steel... I am still kicking myself for selling nice 40 Ford hoods and fenders for $75. . |
01-18-2016, 03:40 AM | #14 |
Re: 41 bumpers
. Here's a 41 Special (or possibly Deluxe) staff car after pearl harbor with it's non ribbed bumpers.. ...those are some Interesting wire cutters, two cutting faces...... It looks like they used Ford truck tail lights? on the front fenders of 41 black out cars... This looks like it was probably the 'good' side judging by the exit wounds? I think this would be early 41 production judging by the 3 piece front fenders. I'll bet you 'the boys' had it back up and running within a day or so of dragging it to the maintenance tent. . Last edited by moefuzz; 01-18-2016 at 09:28 AM. |
01-18-2016, 04:36 AM | #15 |
Re: 41 bumpers
Here is a 1942 Ford blackout model. You will notice that it also has the same kind of Tail Lights as the 1941 Ford Blackout model. I believe that hey used these "different" Tail Lights, as they could be "blacked out" more effectively. Also note that this 1942 Ford has the same "Profile" as the 1941 Ford Super Deluxe Models, however, I am led to believe that they are not interchangeable, as the Bolt Holes are in slightly different locations? These 1941 Ford type bumpers were only fitted to the base level cars. It is hard to see, but the rear bumper is also Ford script. |
01-18-2016, 04:57 AM | #16 | |
Re: 41 bumpers
I've seen this on a few 41's as well, I'm not so sure that calling it a '46' trim is correct.... That being said, Production could have been different here in Canada as there was lots of variation for such a short model run. I have also seen variations with a larger stainless trim with the Ford script above the trunk handle which leads me to believe that the rear license plate was relocated to a bracket possibly off of the drivers bumper arms. This was quiet a few years ago and the old memory is low on definition. Mind you, that could have been some ones custom job using a 50ish Ford/Monarch trunk trim... Who knows.. Last edited by moefuzz; 01-18-2016 at 05:20 AM. |
01-18-2016, 05:05 AM | #17 | |
Re: 41 bumpers
Yes, the 42-48 bumpers are different. Also, regarding those '41 tail lights.. They are really nothing more than a removal of the actual bezel/surround and placing a can in it's place. The tail light bucket (the part that mounts to and behind the fender) is still there, they just removed the outer housing and modified a "tuna can" to bolt to the existing bucket. I think they even reused the rubber tail light to fender gasket but they ate the tuna first.. Not sure about 42... . Last edited by moefuzz; 01-18-2016 at 09:23 AM. |
01-18-2016, 06:39 AM | #18 |
Re: 41 bumpers
This 1942 Ford Deluxe has the 1941 Ford Super Deluxe "lookalike" Bumpers. When I asked this question on Ford Barn last year, I received this reply from Barner Brian:- A stock 41 Ford Super Deluxe bumper has the two holes for the license plate mounting bracket and the factory bolt holes are 15 3/4" approximately apart center to center. The 42 Deluxe bumper does not have the two license plate mount holes and the factory bolt holes are 13 1/16" apart approximately center to center. Ford apparently used the 41 bumper core and simply re-stamped the holes to provide for the different grille arrangement in 1942. Simply put they spread the bumper guards wider off center on the 42 application. Now, I went back last night and looked at the blue 42 Ford you have pictured an did has the license mounting bracket so it could be a correct 41 Super Deluxe bumper but if that is the case I don't know what bumper irons may have been used. I hope I have not confused you. If you are looking at bumper core for 1942 Deluxe you need the measurements and the understanding it did not have the two holes for the license plate mounting bracket. While they look the same, the Bumpers will not interchange between the 41 & 42 Fords. To sum up, while they look identical, they are different. |
01-18-2016, 07:07 AM | #19 |
Re: 41 bumpers
I see that cream 41 has 46 stainless trim on the boot lid (trunk) GB Graeme from New Zealand. Regarding that original 1941 Ford, the chrome on the fenders and trunk lid have been added by the owner. Notice that the Strip on the front fender is short? Also note the 3 "hash" strips on the front fender. The chrome strips on the trunk lid might look similar to those fitted to 1946 and 1948 Fords, but if you compare them with the strips on this Australian 1948 Ford Super Deluxe, you will see that they are longer than the original ones. Now before the purists tell me that this car is not a 1948 model, please note that this is how Ford Australia equipped these 1948 Fords. The Australian 1948 Fords never received the modified rear Bumper and restyled Bumper Guards. Nor was the Bumper repositioned lower like they were in USA and Canada. Also, for some strange reason, the same 1946 style trim was used on the trunk lids, which did not match the trim on the rest of the car. All very strange, but this car is correct for the 1948 Australian Fords. The reason for adding this car to this Post is so that you can compare the chrome strips on the trunk lid with those on the 1941 Ford. For safety reasons, Ford did round the bottom corners of the trunk lids, so that you didn't poke your eye out if you happened to walk into one with the trunk lid open. That was one very good idea that the USA didn't think of? |
01-18-2016, 07:38 AM | #20 | |
Re: 41 bumpers
