08-09-2013, 01:56 PM | #1 |
1936 221 CU with Stromberg 97 stalls
My 1936 221 cu flathead with a Stromberg 97 stalls when I come to a stop. I tried adjusting the float using the dry method by holding the carb upside down so the top of the float is level with the edge of the bowl, but that didn't fix the stalling. It runs great otherwise. Any suggestions?
08-09-2013, 03:58 PM | #2 |
Re: 1936 221 CU with Stromberg 97 stalls
does it start right up after stalling??...Mike
08-09-2013, 05:55 PM | #3 |
Needs more idle mixture. Try winding the the two screws out in the base a quarter turn at a time and see if it improves.
08-09-2013, 07:40 PM | #4 |
Is it all standard? Are you running a brake booster? Any vacuum leaks? Vacuum brake of distributor working o.k.?
08-09-2013, 07:59 PM | #5 | |
08-10-2013, 07:34 AM | #6 |
Ken CT, the upside down way is the recommended method by Stromberg using this link http://www.stromberg-97.com/tech_cen...Inst_V3_HR.pdf but I'll give yours adjustment a try. Thanks guys |
08-10-2013, 10:31 AM | #7 | |
08-10-2013, 10:33 AM | #8 | |
08-12-2013, 01:03 PM | #9 |
Ken ct, thanks for the help. I dropped the float level down as suggested. It's a lot better now but still stalls occasionally when stopping. Also, when trying to adjust the idle mixture, the engine/vacuum does not change when turning the needle values all the way in or out.
I also noticed in several postings that you rebuild carbs, what do you charge to rebuild a stromberg 97? |
08-12-2013, 03:21 PM | #10 |
Sounds like one, or both, of your idle mixture screws might be snubbed.
08-12-2013, 07:17 PM | #11 |
This is how I set mine....works ok. Sorry for the bad pictures.
KIM KARDASHIAN ISN'T FLAT, BUT MY MOTOR IS..... http://s818.photobucket.com/home/roglehr/index |
