08-11-2012, 07:28 PM | #1 |
Manifold gasket
I installed a brand new intake and exhaust manifold. I checked it with a metal yard stick which it showed perfectly even. I put on a one piece silver gasket, but after a club meet today it is leaking again. Should I take out the rings that I put in and would it be better if I used a copper gasket. Has anyone ever put on two gaskets???? What would you guys suggest.
Tom.... |
08-11-2012, 07:32 PM | #2 |
Re: Manifold gasket
i always use the copper gasket and the rings when installing new manifolds. new studs, nuts and beveled washers. tighten from inside to out.
08-11-2012, 07:35 PM | #3 |
Re: Manifold gasket
Tom,
If the manifolds have been surfaced a couple of times the rings may be spacing the manifolds out and causing a problem. Charlie Stephens |
08-11-2012, 07:42 PM | #4 |
Re: Manifold gasket
Did you check the block for flat?
Bob |
08-11-2012, 07:44 PM | #5 |
Re: Manifold gasket
he used new manifolds and did not resurface them according to what i read
i also have found that when using new manifolds they did not need resurfacing |
08-11-2012, 08:33 PM | #6 |
Re: Manifold gasket
08-11-2012, 08:57 PM | #7 |
Re: Manifold gasket
I use copper gaskets, no gland rings.......no leaks.
Ed |
08-12-2012, 06:36 AM | #8 |
Re: Manifold gasket
Agree with Ed, I have not used rings in my A's for a very long time. I do not reuse the copper gaskets if I have the manifold off. Gar Williams
08-12-2012, 08:26 AM | #9 |
Re: Manifold gasket
Whenever I use metal clad gaskets (copper steel whatever) I always spray them with Copper Cote gasket sealer. I personally use the gland rings but I always make sure they have clearance, I always retighten a couple of times after a good warm through also. Good luck Clyde
08-12-2012, 12:10 PM | #10 |
Re: Manifold gasket
On my Cabriolet after installing a rebuilt B motor I couldn't get the gland rings installed & it leaked in one area. I installed two gaskets this was four yrs. & several thousand miles ago & it's been fine with no leaks.
08-12-2012, 12:18 PM | #11 |
Re: Manifold gasket
08-12-2012, 12:39 PM | #12 |
Re: Manifold gasket
I don't bolt them together for surfacing, I leave the bolts loose when installing the manifolds, shim between them, and only tighten the 2 bolts enough to compress the washer ---perhaps with todays fuel less heat is needed to vaporize the fuel and some space between the manifolds can help with the dreaded vapor lock problem ---my car has resisted problems with the sort of gasoline sold today
I also resist removing metal from any original part by surfacing --it's hard to put back later---what happens when you have a several time surfaced intake and you get a new ex manifold----do you cut down the new one to match the original intake? It has worked for me, I used the copper gaskets I had,no sealer, and 3 gland rings that would fit, it's been 25 years, my manifold is cracked now, but I don't want to disturb it until the 25 year old muffler falls off, I think I will force in some furnace cement into the crack The gaskets were used when i put them on ---the new ones that I had used kept failing |
