05-27-2013, 08:40 AM | #1 |
Battery Charging Question
I have removed the 6 volt battery from my father's model A for charging. I have topped of the cells and plan to charge the battery today. When I test the cells with a hydrometer what should they measure. I'm sorry for the basic question I was once an auto-mechanic but I have been away from it for over 20 years now
Thanks Mike |
05-27-2013, 09:11 AM | #2 |
Re: Battery Charging Question
I haven't seen a batt in a long time with access to the acid. Measure across the terminals when fully charged. 6+ volts. Make sure cables and ground on the frame CLEAN.
Paul in CT |
05-27-2013, 09:14 AM | #3 |
Most likely more then you need to know but see link
http://www.batterystuff.com/kb/artic...-basics.html#6 |
05-27-2013, 10:14 AM | #4 | |
Tom... |
05-27-2013, 10:25 AM | #5 |
Only top off a battery after charge --the level rises as it charges, before charge the electrolyte only needs to cover the top of the cell.
when it is filled before charge there is a good chance it making a mess If you are trying to take hydrometer readings after filling but before charging you will get low readings because the water you added is not mixed in. |
05-27-2013, 12:14 PM | #6 |
Presuming the battery is not of the sealed type (that is, you still have access to each cell), then taking a specific gravity reading on each cell with the hydrometer will frequently point up the weak cell (similar to a compression check). Typically, a fully charged lead-acid battery will have a specific gravity around 1.280 (sometimes spoken “1280”) so that if you get a series of readings for the cells of around 1.265 to 1.280 but one cell reads 1.090 (for example) you can presume – if this cell doesn’t return to normal with charging – that this cell has failed and the battery ought to be replaced. If, on the other hand, the electrolyte level covers the plates, all specific gravity readings are fairly consistent (+/-) and increase with charge (and come up to somewhere around 1.280) then the battery is probably good and the problem lies elsewhere (elsewhere being – usually – corroded terminals/connections or a failed component, depending on the problem). If all the battery cell specific gravities are consistent but do not increase (significantly) with charging (or the charging rate in amperes doesn’t decrease with time) the battery has reached the end of its life and should be replaced. If the battery is a fully-sealed unit, and you don’t have access to the cells, then the only reliable test I know of to ascertain battery condition is a load test that actually puts a resistive load on the battery long enough to determine if it’s still good. When you are done measuring the specific gravity, rinse the hydrometer out with tap water so that the electrolyte (sulfuric acid, H2SO4) doesn’t get all over everything. And if you need to top off the electrolyte level, use distilled water (please don’t take offense at this advice, inasmuch as you never know the experience level of whomever posts the original question or reads the subsequent replies). Small amounts of tap water will not cause the battery to instantaneously go belly-up, but the minerals in most tap water (and the chlorine – or whatever treatment agent your municipality uses - in many municipal water supplies) don’t help battery life. Btw, if you don’t have a battery hydrometer but do have a multimeter, you can actually read the voltage from one terminal through each cell successively by momentarily dipping one multimeter probe tip into the electrolyte. Thus, starting with the grounded terminal of the battery, you should see about 2 volts between that terminal and the first cell, 4 volts between the ground terminal and the second cell, and so on (each lead-acid cell generating about 2.2 volts DC which – with internal resistance – results in about 2 volts per cell). And, lastly (based on my experience on several occasions following my forgetting to turn off the lights after parking my coupe) you would be surprised how many times you can start your Model A with the hand crank and a supposedly “dead” battery. If you know how to do this (there is a good description and photo under “hand cranking” in the Victor W. Page’ “Model A Ford Construction, Operation [and] Repair for the Restorer”) this may help tell you whether you have a battery problem or starter (or ignition) problem without schlepping the battery back to the auto parts store. Besides, imho, every Model A driver ought to know how to start his/her Model A with a hand crank. Ok, a long post and probably more than most want to know about hydrometers, lead-acid batteries and hand-starting a Model A. At least I didn’t include battery equations, temperature-correcting hydrometer readings, freshening and equalizer charges, test discharges, electrolyte agitation systems (probably redundant on a frequently driven Model A) and plate construction. Once a submariner, always a submariner…
Skip Keyser Napa Valley A's Olympic Vintage Auto Club (1980-1982) MARC of San Diego (1977-1978) MAFCA (since 1978) MARC (since 1977) ---------- Model A owners belong in their Model A’s; Model A’s belong on the road. |
05-27-2013, 12:26 PM | #7 | |
Mike |
05-27-2013, 04:28 PM | #8 |
Battery needed to be replaced.
Thanks again for your assistance Mike |
