03-09-2021, 02:17 AM | #1 |
99a main bearings
Can any one advise me a stockist who has the current manufacture main bearings for these engines,(39-47)2.499 std (King,Clevite or others)
Thanks Lawrie |
03-10-2021, 09:09 PM | #2 |
Re: 99a main bearings
After a lot of hunting down , I ended up getting a set of clevite mains, as well as a set of King ones.
Lawrie |
03-10-2021, 10:16 PM | #3 |
If the scaresage gets too bad they can always be whittled out on a lathe.
03-11-2021, 02:07 AM | #4 |
Pete, I was going to look at fitting the 8ba centre and front mains but machine the small tag slot on the other side, and using the 81 rear main.
Lawrie |
03-11-2021, 08:21 AM | #5 |
I've used both Clevite as well as King bearings lately - both are high quality. I'm more concerned with bearing clearances than the brand . . . would not have a problem running most any of them.
03-11-2021, 09:29 AM | #6 |
03-11-2021, 12:05 PM | #7 |
8BA and 59AB front and center main bearings are interchangeable. The rear thrusts are different.
03-11-2021, 03:53 PM | #8 |
03-11-2021, 05:12 PM | #9 |
Are the 99A and 59A different? I know the centre and front are the same 59A and 8BA. The rears are different 59A/8BA.
So are 99A and 59A different? I put a 99A together but just reused the old bearings. |
03-11-2021, 09:40 PM | #10 |
99A would be 39 Merc and they had 2.499 main journals, so think they would be the same.
03-11-2021, 09:43 PM | #11 |
