08-08-2020, 11:30 PM | #1 |
Removing steering wheel center cap
I am having a difficult time removing the center cap of the steering wheel on my '51. I am using 2 putty knives and I'm terrified of damaging the cap or steering wheel. Maybe not terrified but I'd like to avoid it... lol. I've applied ATF with a needle oiler hoping it would loosen things up. Is there spring clips holding it on?
Any input would be appreciated. |
08-09-2020, 12:17 AM | #2 |
Re: Removing steering wheel center cap
It might be a slight push in and twist of a turn and should pop off.
08-09-2020, 07:18 AM | #3 |
As stated, using a rubber jar top remover pad (or something similar),to get some grip, turn the nut cover counter clockwise to remove.
08-09-2020, 10:34 AM | #4 |
Thank you very much!
08-09-2020, 10:42 AM | #5 |
WABOOM: Really glad you found out. My idea was incorrect. Funny, I thought I took mine apart by prying it off. Glad you got right info.
08-09-2020, 09:53 PM | #6 |
08-10-2020, 12:20 AM | #7 |
Never try prying it off.It wasn't designed that way
08-17-2020, 07:20 PM | #8 |
Update. I got the center cap off! I thought the entire bezel came off counter clockwise... I was wrong. Just the center bullet comes off first. Then there is screws underneath to unbolt the bezel. I just about ruptured the tendons in my wrists trying to twist something that doesn't turn. My dumb mistake.
Next I will make a fixture to pull the steering wheel from the column. Thank you for your replies gentlemen. |
