Old 10-29-2020, 03:12 PM   #1
zuburg
zuburg's Avatar
Default Ford-O-Matic case stamp identification
I have been looking through all the Transmission identification postings to try and identify the Ford-O-Matic transmissions I have, but have failed to find the exact ones I have. Can anyone tell me what I have for the following case stamps:
PAK-7006-C
PMB-7006-D
Also, what stamp code would indicate a transmission from a super-charged Ford?
zuburg is offline   Reply With Quote
Old 10-29-2020, 03:32 PM   #2
dmsfrr
dmsfrr's Avatar
Default Re: Ford-O-Matic case stamp identification
'55 / '57 T-Bird Fordomatic ID numbers...
  • 1955 – PMB -C
  • 1956 – PAW – C, air cooled
  • 1956 – PAW – F, water cooled
  • 1957 – PBA – C, 4V
  • 1957 – PBA – E, S/C and 8V
a few more numbers at this link...
https://www.ctci.org/fordomatic-tran...dentification/
Old 10-29-2020, 03:39 PM   #3
zuburg
zuburg's Avatar
Yes, I saw that information in an earlier post. Does that mean my PMB-7006-D is also from a T-bird?
Any idea what the PAK-7006-C was from?
Old 10-29-2020, 03:44 PM   #4
dmsfrr
dmsfrr's Avatar
I don't have a complete list of transmission ID numbers.
Old 10-29-2020, 05:03 PM   #5
KULTULZ
KULTULZ's Avatar
Post Re: Ford-O-Matic case stamp identification
PAK-7006-C
PMB-7006-D
The numbers above are CASTING ID NOS for the main case (7006) of the trans assy. PN PREFIX PMB would indicate MERC-O-MATIC (MED CASE).
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 10-29-2020, 05:52 PM   #6
rotorwrench
rotorwrench's Avatar
I've never made much sense out of the Borg Warner/FOM numbering system. The first number, PAK-7006-C, was used in the 1955 Ford 272 with 2V applications and it's a small case transmission.
The second number, PMB-7006-D, I could not identify for certain since it wasn't listed in this listing. https://www.charlietranny.com/FordomaticID.htm
The PMB prefixes that were listed were as follows. The PMB-7006-A was used in 1955 Mercury applications with 292 and 4V carb. The PMB-7006-B was used in 1955 Ford 292 with 4V carb applications. The PMB-7006-C was used in 1955 T-bird with 292 and 4V carb applications. All of these are medium case transmissions.
It could have been a T-bird application that was short lived in that time frame. Maybe late in the model year but this is all just speculation.
Old 10-29-2020, 07:38 PM   #7
KULTULZ
KULTULZ's Avatar
The TRANS ID will have BASIC PN 7003 (7003 being an assembly).
A main case will have a CASTING ID BASIC ENGINEERING PN 7006.
- WHY IS IT ... -
