#1 |
I need help. I received a new Weber carb (manual choke) with intake manifold for Christmas 2015. Instructions received with the carb read that it was pre-adjusted for the Model A Ford. I started the car once a week since then and the car ran smooth and strong. Yesterday, I started it and it idles smooth; however, it will not run above an idle. The engine cuts off when I attempt to speed it up.
I adjusted the idle speed when I installed the carb back in December but have not adjusted any other screw on the carb. Yesterday, i cleaned and reset the points to .018, changed out the condenser and changed out the coil. I checked the gas flow to the carb and it flows without restriction. I took the filter off the carb and the gas drips/dribbles into the carb. Is the gas supposed to drip or atomize in the throat? What else can I check? I do not want to start turning screws for fear of really getting the carb out of adjustment. I appreciate all of your info and advice. Bill Lee/Virginia Peninsula |
#2 |
