06-05-2012, 09:56 PM | #1 |
Des
How do I stop contact points burning out on the Model A distributer?
06-05-2012, 10:43 PM | #2 |
Re: Des
You must have a bad condenser or wrong coil. Oil on points contacts is also bad, but I've never seen that happen on a Model A.
06-05-2012, 10:48 PM | #3 |
Re: Des
If you are using a 12 volt battery you will need to use a resistor at the coil to drop the voltage to 6 volts to the distributor.
06-05-2012, 10:49 PM | #4 |
Re: Des
Make sure your charging voltage is not too high.
Bill W.
06-05-2012, 11:43 PM | #5 |
Re: Des
12V battery, or high charging voltage, shouldn't hurt the points.
Replace the condensor. |
06-06-2012, 11:04 AM | #6 |
Re: Des
