04-06-2015, 05:00 PM | #1 |
Fender Fail Update
Well, I was using a "nib file" to shave off the runs and sags of my botched fender underside paint job (picture 1) for over an hour when it became clear that I would not be satisfied with the end result. So I listened to my own advice (slow down - take your time -do it right!). I loaded 220 grit in my palm sander, sanded it all down again, and reshot the fender underside.
Now a week later, while my cat was unimpressed (picture 2), I am now satisfied with a job I consider well done. (Picture 3) |
04-06-2015, 05:04 PM | #2 |
Re: Fender Fail Update
BTW the next show i go to where I see a model A with perfect fenders - top side and underside, I'm going to shake that owner's hand because I KNOW how much work it takes to get there!
04-06-2015, 05:10 PM | #3 |
That's a very good looking job on that fender!
04-06-2015, 06:01 PM | #4 |
Don't forget to under coat it so you won't get any chips in the paint !
04-06-2015, 06:03 PM | #5 |
How well did your palm-sander work? We have tried everything from micro DA sanders with 2" or 3" Hook-it sanding pads, ...to Palm sanders but we found the productivity is just as fast with block sanding by hand on a foam pad.
04-06-2015, 06:53 PM | #6 |
04-06-2015, 09:14 PM | #7 | |||
I usually don't use it to "block sand", but here the panel shaping was already "done" (it is a NOS fender - so not much work needed.), The sander made quick work of erasing the sags & runs, and getting the bad coat of enamel smooth and level - ready for respray. BTW Although I have a Porter Cable DA for buffing/polishing its long handle makes it no good for doing the underside of fenders. Since I don't have an air source that will drive an air tool I use a modified (I cut off the saw dust collection chute) Milwaukee DA sander (picture 2) with a hook & loop back and Chemical Guys pads. It has the same speed control as the Porter Cable, works great, and easily gets into all areas of the fender undersides. Quote:
If wanting to do as much of my restoration myself as I can and expanding my skills set makes me a novice, then that's what I am. For block sanding vs. palm sander see above. |
04-06-2015, 10:32 PM | #8 |
I used a wooden paint stick with sandpaper wrapped around it, I could form it around the curves and it would not leave flat spots
John |
04-07-2015, 12:10 AM | #9 | |
I might also add that based on our experience of doing fenders, the Palm-Sander isn't faster nor is the quality level what I or my customers are seeking. |
