06-19-2013, 08:57 PM | #1 |
V-12
There is a Lincoln V-12 for sale on ebay-is this a fair price or an over inflated ebay price. These engines have always interested me. Seems like the seller is using a lot of salesman speak-don't know if you can get much speed equipment for these engines. What was the idea with going to a V-12, based on looking at the bore size they could not be much bigger than a v-8. Here is a link to the engine: http://www.ebay.com/itm/LINCOLN-V12-...f59e4c&vxp=mtr
06-19-2013, 09:02 PM | #2 |
Re: V-12
I believe - subject to correction - the idea was to have a smoother power plant for the higher ticket cars. Smoothness was a big selling point in the '30s & '40s. FWIW
Henry |
06-19-2013, 09:06 PM | #3 |
Re: V-12
Sorry for my answer but it might be worth a lot more and it might be worth a lot less. I am guessing a lot less and that is why I do not own it.
06-19-2013, 09:13 PM | #4 |
Re: V-12
I agree with Henry ,they were built for thier smoothness. Believe me, there is nothing inexpensive for this engine . I'm building two of them now. Speed equipment is absolutely through the roof. A pair of heads run around 3 grand for a pair and multiple carb intake is over 1 grand. Pistons run about 700 then the bearings are around 300 per set for the mains and rods. Then you got to figure machine work. As far as the bore size , it's much smaller than the V8. That block looks to be the later block which is 2 7/8 bore.
06-19-2013, 09:46 PM | #5 |
Re: V-12
I've been interested in these engines as well. There's what looks to be a complete one near me for cheap but it scares me to try and tackle building it.
06-20-2013, 06:24 AM | #6 |
Re: V-12
Imagination is more important than knowledge. |
06-20-2013, 09:50 AM | #7 |
Re: V-12
I thought it was because the 'Green Hornet' needed a car that made just the right sound.
Don't need to be 'souped up' because in the movie the 'Green Hornet' asks his valet, 'Kato', "How fast will she go?" Kato responds, "faster than 200"
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 06-20-2013 at 10:10 AM. |
06-20-2013, 11:04 AM | #8 |
Re: V-12
My friends with v12s say around here 600-800 for a core engine is normal. Any good flathead machinist can handle the v12s. If you do get it, ditch the hydraulic lifters and put in adjustibles. Expect to spend lots on speed equipment as stated above.
06-20-2013, 12:33 PM | #9 | |
Re: V-12
06-20-2013, 04:03 PM | #10 |
Re: V-12
The last V 12 I rebuilt was at least 8 years ago and that cost me about $4500 for parts and machine work and I assembled the whole mess. I would not do away with the hydraulic lifters. If you go with solid lifters, you MUST regrind the camshaft for solids or else tear down the engine and replace the cam in about 5000 miles. Basically the engine is the same as a Ford V 8 with some improvements for smoother operation.
06-20-2013, 04:26 PM | #11 | |
Re: V-12
06-20-2013, 09:11 PM | #12 |
Re: V-12
Yea V12s came with hydraulic lifters starting in 38. The real problem now is finding a set of 24 that will work like they are supposed to. If you do find them they are very expensive.
06-20-2013, 09:19 PM | #13 |
Re: V-12
Question; are the v12's a stretched std V8, or are they a stretched V8 60?
Somebody earlier stated 2 7/8" bore. Is that a V8 60 bore size? |
06-21-2013, 09:55 AM | #14 |
Re: V-12
It's really neither , the V12s from37 to about 40 were 2 3/4 bore then they went to 2 7/8 then in 42 it went to 2 15/16 and after the war through 48 they went back to 2 7/8 . The 42 block can be bored to use the 3 1/16 pistons from the V8.I just took a 2 7/8 block that is no good and my machinist bored it to 3.160 before it hit the water jacket . There is very little parts that will interchange between the V12 and V8 . The valve train and cam gear is about it. The V8 oil pump is the best way to go but the baffle in the pan has to be modified some.
06-21-2013, 08:01 PM | #15 |
Re: V-12
Thanks Ken. I have never seen either (V8 60 or V12) in the flesh. I have no doubt there are a few around N.Z. but "In the day" our little country was tied to mother England by her apron strings and it was unusual for vehicles to come from anywhere else. In saying that, I saw a V12 motor for sale on a popular Kiwi website not that long ago.
