Old 10-15-2018, 04:26 PM   #1
rfitzpatrick
Default Quick Point Gap Setting Tool
OK, I've another issue -- have a Point Gap Setting Tool that I used to adjust my points on my Pickup -- and used this tool. The manual says the points are to be set at 18, after I used the Tool, I double checked my setting and found them at .35. took a measurment of the tool piece that you incert between the points and it was 35. If anyone else has this tool, could you verfiy and alert me of your readings, and if they are good -- plz tell me where you got your gap setting tool from -- I can not recall whom I got mine from, tho I've alerted Berts and asked for advise/assistance as I've often ordered parts from them.
Thanks
rfitzpatrick is offline   Reply With Quote
Old 10-15-2018, 04:34 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Quick Point Gap Setting Tool
I use a feeler gauge, toss the tool!
Old 10-15-2018, 04:39 PM   #3
quickchange
quickchange's Avatar
Sounds like a plug gap tool not points ,
quickchange is offline   Reply With Quote
Old 10-15-2018, 04:51 PM   #4
rfitzpatrick
Berts: Part Number --- A-12198 Quick Point Gap Setting Tool
Old 10-15-2018, 05:02 PM   #5
leo
leo's Avatar
The problem with this tool is it makes the assumption that all the possible variables are always the same and good so the one size that the tool measures for will always be correct.
leo is offline   Reply With Quote
Old 10-15-2018, 05:36 PM   #6
160B
160B's Avatar
https://modelastore.com/index.php?ro...oduct_id=18562
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 10-15-2018, 05:57 PM   #7
dpson
dpson's Avatar
Those point setting tools have been around for years for Fords and other makes and models and work well. The .35 thickness of the setting device takes into account the thickness of the ring that slides over the cam. It sounds like you make not have had the ring pushed all the way down on the cam, otherwise the gap with the ring removed and the points open on the high point of the cam should be around .18 +/-.
dpson is offline   Reply With Quote
Old 10-15-2018, 05:58 PM   #8
KGBnut
KGBnut's Avatar
I don't use a feeler gauge. The standard thread for the adjustable part of the ignition points is 32 threads per inch. I put them on the high part of the cam, turn the adjuster in until the points just close (a powered test light helps), then turn it out 5/8 of a turn. That will put you right at 19 thousandths.
Ken
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
Old 10-15-2018, 10:00 PM   #9
31a
I have used the point gap tool and find it works great for me no problems
31a is offline   Reply With Quote
Old 10-15-2018, 10:38 PM   #10
daveymc29
daveymc29's Avatar
The "Ace" Inventor. I came up with this idea in my Austin Healey days and went to a tool maker to test his skill and see what he thought of the idea. He was quite sure it would work and with a little smile, told me to go to our local auto parts house and buy one there and we could try it on his car. So much for the wealth I was hoping would flow from the royalties on that one, So I went back to work for a living. Using my brain was way to slow.
daveymc29 is offline   Reply With Quote
Old 10-16-2018, 10:16 AM   #11
Dick Steinkamp
Dick Steinkamp's Avatar
Ken
Great idea! Thanks, Ken.
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 10-16-2018, 10:35 AM   #12
jrelliott
jrelliott's Avatar
In an emergency, you can use the ignition wire( wire from distributor to spark plug) to set the gap and it will run. Later use the feeler gage.
Old 10-16-2018, 12:08 PM   #13
100IH
Fore those that use a feeler gauge, try to find the mini feeler gauge. About 1/4" wide and about 1 1/4 long. same as larger sets but just the blades needed for points and they are stiff and not so flexible. Because of the lighter weight, you can actually feel, even with the light spring pressure on the movable arm. Much better.
100IH is offline   Reply With Quote
Old 10-16-2018, 12:54 PM   #14
J Franklin
J Franklin's Avatar
I think I need a diagram for this one. In an emergency try a credit card.
PS I got it.
Old 10-16-2018, 01:40 PM   #15
CarlG
CarlG's Avatar
“Back in the day” I would use a paper match book cover to set the points. Just not many of those around any more.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 10-17-2018, 12:31 PM   #16
rfitzpatrick
Steve at Berts cleared up my problem I caused. You never use the Quick-Point Gap
Setting Tool (A-12198) without using the Thimble. Don't use the setting tool to re-check your points after the Thimble has been removed either -- as this was my 'problem' I created.
Steve was very patient with my questions --
Thanks
Old 10-18-2018, 01:51 PM   #17
Benson
Benson's Avatar
Old 10-18-2018, 04:32 PM   #18
sphanna
sphanna's Avatar
RE: post # 8 : by KGBnut
Search " setting point gap without feeler gauge" on this forum and you will find another way to open your points to 20* but I think easier than estimating 5/8 of a turn.
I admit the there is way too much info in this post but use the info in the last half for another way to get the 5/8 turn.
Steve Hanna, Polk City, IA
sphanna is offline   Reply With Quote
Old 10-20-2018, 09:24 PM   #19
Fred K-OR
Fred K-OR's Avatar
This is a great tool. Works for this guy who needs something like this.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 10-20-2018, 09:43 PM   #20
vernon
Using a feller gage close the points with the gage between them tight, then back off slow until the gage drops.
Vern
vernon is offline   Reply With Quote
