Old 05-26-2015, 01:27 AM   #1
1oldtimer
1oldtimer's Avatar
Default 1928 Tudor structure
Does anyone have pictures of the 1/4 panels without the interior panels. Looking for details on wood placement and brace bottoms. Mine has been replaced poorly and the braces that hole the 1/4 windows are loose at the bottom. Also any pictures on how the rear seat pan attaches, mine is hooked the wood but is free floating also.
Thanks.
1oldtimer is offline   Reply With Quote
Old 05-26-2015, 02:06 AM   #2
1oldtimer
1oldtimer's Avatar
Default Re: 1928 Tudor wood structure
Ok, I found some. Looks like I'm missing a panel that is bolted or welded to the floor and bolts to the brace. How about the rear seat riser bolting to the floor?.
Old 05-26-2015, 06:38 AM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Here's a good thread:
https://www.fordbarn.com/forum/showth...udor+rear+wood
Here's another even better thread:
Here's another good thread:
https://www.fordbarn.com/forum/showth...+wood+pictures
If you use the Fordbarn search box in the upper right, and do a search for "rear tudor wood" you will find several good threads on the subject.
Old 05-26-2015, 06:58 AM   #4
Mitch//pa
more pics of my 30 tudor wood and other items in this album
http://fordbarn.com/forum/album.php?albumid=2159
Old 05-26-2015, 09:56 PM   #5
1oldtimer
1oldtimer's Avatar
Thanks Tom, I did see those threads. Mitch's post is where I found the picture. I was wondering if anyone has a close up detailed shot of the part with the arrow pointing to it.
Old 05-27-2015, 05:30 AM   #6
Mitch//pa
there is no wood where your arrow points to
Old 05-27-2015, 11:25 AM   #7
1oldtimer
1oldtimer's Avatar
I have the wood parts sorted out thanks to your and Brents posts. It looks like there's some type of metal brace attached to the body frame, the door post frame and the panel that the 1/4 window regulator bolts to. Mine is missing on both sides, I wanted a close up so I can either make them or find them if they're replaceable (Also notice the strap welded in to shore up the body frame).
Thanks again for everyone's help.
Old 05-27-2015, 11:40 AM   #8
1oldtimer
1oldtimer's Avatar
It looks like it might stop at the rear seat riser.
Found another and it does stop at the riser (Thanks Brent)
Does anyone have a larger picture of this metal piece, something I can zoom in on.
Old 06-02-2015, 01:05 AM   #9
1oldtimer
1oldtimer's Avatar
Default Re: 1928 Tudor structure
I'm repairing the B pillar bottom now. Anyone have a larger picture of that panel.
