12-26-2021, 03:06 PM | #1 |
Tight crank gear
Is there a technical reason the crank gear that drives the cam gear has to be so tight on the crank? I got mine off using an impact gun on a beefy puller. I'm about to put the new one and it's equally tight. I've worked on plenty of engines over the years and never experienced a crank gear being so tight. Is there a technical reason for the tightness? I can't think of one.
Ken Eastern Ontario |
12-26-2021, 03:56 PM | #2 |
Re: Tight crank gear
