Old 05-24-2015, 08:46 AM   #21
Juggler
Juggler's Avatar
Default Re: New Thomas head script
Juggler is offline   Reply With Quote
Old 05-24-2015, 08:50 AM   #22
Tod
I should also add that the inside area of the water pump is actually to print.
Metal walls will be correct and consistent.
BTW, thanks, Juggs.
Tod
Tod is offline   Reply With Quote
Old 05-30-2015, 05:02 PM   #23
Tod
Well, we will see how the script looks soon enough. I am cutting the pattern right now. Should be finished in a couple of days. The chambers/deck part of the pattern is already cut.
Tod
Old 05-30-2015, 07:47 PM   #24
glenn in camino
glenn in camino's Avatar
I have a repo, Dan Price, Thomas 7-1 head on my highly modified model B block in a 1930 deluxe delivery. Runs really strong.
Old 05-31-2015, 08:38 PM   #25
jim1932
jim1932's Avatar
OK...going to play devils advocate. which is better the winfield or the Thomas? both 7:1 of course
Short URL: http://smu.gs/14g7eDW
jim1932 is offline   Reply With Quote
Old 06-01-2015, 04:18 PM   #26
Bick in New Zealand
Bick in New Zealand's Avatar
One suggestion I would make if you haven't already done it is to beef up the area around the distributor locking screw. This seems to be a weak area on the two aluminium heads I have.
1928 Roadster (CA67)
1931 Deluxe Coupe RHD
1931 Victoria RHD
Model A's don't leak oil they just mark their territory.
Bick in New Zealand is offline   Reply With Quote
