12-27-2020, 04:05 PM | #1 |
Removing starter drive mechanism from shaft
Got a remanufactured starter from Napa and need to swap over the drive. Bendix spring came off easy enough. Curious about the ratchet portion of the drive. Looks like a keyway at the top along with the pointed nose bolt for the bendix spring holds the top in the place.
The one starter I'm getting the parts from is a bit rusty and I have the drive soaking currently. I'm assuming a small puller will pull this from the shaft? Any other tips/tricks? Thanks, |
12-27-2020, 04:11 PM | #2 |
Re: Removing starter drive mechanism from shaft
remove bolts push down on drive remove keyway and then pull off shaft keyway is only in top part
12-27-2020, 10:15 PM | #3 |
