Old 02-23-2024, 01:33 PM   #1
Zeke5180
Question Spark plugs - 6 volt, 12 volt difference
I have searched the forum foe a possible answer but cannot seem to find one.
I have a 37 Model 78 slantback that I converted from 6-volts to 12-volts. It has the stock 221cu in engine with a two-deuce manifold. I'm using the recommended Champion spark plug, UD16.
My question is, since I changed from a 6-volt system to a 12-volt system should I consider using a different style plug? The question may be irrelevant since the car seems to rum fine on the current plugs.
Any thoughts.
Thanks, Zeke
Zeke5180 is offline   Reply With Quote
Old 02-23-2024, 01:38 PM   #2
tubman
tubman's Avatar
Default Re: Spark plugs - 6 volt, 12 volt difference
Spark plugs don't care what the primary voltage is, just secondary voltage. It sounds like yours is just fine. If it weren't, the ignition system (most likely the coil) might need to be changed, not the spark plugs.
Old 02-23-2024, 01:40 PM   #3
Terry,OH
Terry,OH's Avatar
You either have to change the ignition coil to 12V or use a ignition resistor in series with the coil to drop the 12V to the proper voltage for the coil. It is the coil supplying high voltage to the spark plugs. A good 6V system and a good 12V ignition system may supply about the same voltage to the plugs so there is no need to change the plugs.
Old 02-23-2024, 01:41 PM   #4
derek costello
Tubman is right...........
derek costello is offline   Reply With Quote
Old 02-23-2024, 10:32 PM   #5
JayChicago
JayChicago's Avatar
Yep. And so is Terry OH.
JayChicago is online now   Reply With Quote
Old 02-24-2024, 07:57 AM   #6
Gene1949
Gene1949's Avatar
I've always thought 12v was a "dryer" (as in amperage) spark. My stock flatty seems to like a 45 thousandth plug gap. Throttle response starting etc.
I'm running a magnetic pickup, HEI brain firing a early 2000 GM E coil
Gene1949 is offline   Reply With Quote
Old 02-24-2024, 11:31 AM   #7
petehoovie
petehoovie's Avatar
Old 02-24-2024, 11:42 AM   #8
Zeke5180
Thanks to all for your response, much appreciated.
Zeke
