04-19-2014, 07:25 PM | #1 |
9" or 9.5" clutch disc with no springs?
Does anyone know of an available clutch disc without any springs?
I made the mistake of machining a bit too much off the flywheel and even with thinning down the crank bolts its still REALLY close to hitting. If not, has anyone modified a clutch disc to eliminate the springs? thanks Zach
-WANTED-
Pre-War Speed Equipment Davies or Morrison Intake Manifold 77-6050B, 81AS - 81SB - 99AS - 99SB 19AS cylinder heads |
04-19-2014, 08:43 PM | #2 |
Re: 9" or 9.5" clutch disc with no springs?
Some of the original Model A's had a 9in. disc 1-3/8 spline with no springs. I don't know if you find one of them now. Maybe ask the boys on the Model A site. Walt
04-19-2014, 08:58 PM | #3 |
Thanks Walt, I'll put a post over there too...
This is actually on a model-A but its a V8 flywheel. thanks Zach
-WANTED-
04-20-2014, 01:04 AM | #4 |
ARP makes flywheel bolts and the head is very thin.
Half the thickness of a stock one |
04-20-2014, 08:42 AM | #5 |
Zach,
I have a 9" disk with a solid hub. Came with a big pile of parts I acquired long ago. The guy put V8 flatheads in 8N/9N tractors so I always assumed it was from a tractor? Here's a couple pics: It's been used, but the lining appears to be usable. It's yours for the price of shipping if you'd like to give it a try. Chris |
04-20-2014, 11:09 AM | #6 |
04-20-2014, 04:33 PM | #7 |
Here is one out of a model A, yours for shipping Zeke
Only problem with retirement is never a day off |
04-20-2014, 05:07 PM | #8 |
Our 49 Ferguson TE20 Tractor has the 9" disc with no springs.
