12-31-2017, 01:42 PM | #1 |
thread renovation ?
I'm working with antique aluminum parts, removing brass plugs frozen with time 80+ yrs time. Feeling lucky to have removed some parts, so far, without breaking any casting. Aluminum oxide has made the bond and has indicated that the aluminum threads should be cleaned.
If I do not have right sized taps for the, too large hole, do you know of any way to clean these alum threads without damage ? I will put some lube on reassembly to help prevent recurring problem. |
12-31-2017, 01:46 PM | #2 |
Re: thread renovation ?
you get a bolt that same size and cut some slices in it with the whizz wheel. you have now made a thread chaser!
12-31-2017, 01:57 PM | #3 |
12-31-2017, 05:57 PM | #4 |
Good idea that cas3 has. I have one of these kits which is hardened steel that is configured the same as he mentioned. This kit works very well!
http://www.sears.com/craftsman-48-pc...p-00942275000P |
12-31-2017, 06:35 PM | #5 |
Here's a whole bunch of ideas on how to remove aluminum oxide without
damaging the aluminum. https://www.google.com/search?ei=OXN....0.aRtxl_zyFL0 |
12-31-2017, 06:57 PM | #6 |
01-01-2018, 02:17 PM | #7 |
If the hole's are already too large, you can repair them with a Helicoil kit. They are sold at most auto part's stores. you tap the hole with a special tap and install the helicoil for the proper size bolt. Al
01-01-2018, 05:29 PM | #8 | |
