10-05-2022, 07:17 PM | #1 |
Axle Nut source
Looking for a source of hardened axle nuts for a 1940 rear axle. I was installing the rear driver's side hub when I went to torque the axle nut to 200 ft/lbs. the nut stripped. I only got to 175 ft/lbs when the nut began to turn. These are brand new nuts from one of the vendors many of us use. When I purchased them I asked if they could take 200 ft/lbs of torque and was told that they hadn't received any complaints and the manufacturer of the nuts supplied most of the well-known early ford parts vendors.
This picture shows the nut after letting go. The next picture shows the axle threads after running a 5/8-18 die over the threads. I tried the other new nut and this one never made it past 150 ft/lbs. I know I can't be the only one who has come across this problem so if any of you have a good source for quality axle nuts please let me know. By the way 200-220 ft/lbs is the recommended torque value for this axle. Thanks |
10-05-2022, 08:08 PM | #2 |
Re: Axle Nut source
I had issues with most suppliers reproduction nuts stripping. Third Gen Auto was the solution. I also picked up a compression repair nut for my emergency kit from them too.
10-05-2022, 09:31 PM | #3 |
Re: Axle Nut source
Thanks Ozyrodder, I'll give them a call in the morning and see what they say.
Tony |
10-06-2022, 01:36 AM | #4 |
Re: Axle Nut source
Try south side obsolete .
Barnfind 08 on the barn ,he has NOS ford ones. Lawrie |
10-06-2022, 02:01 AM | #5 | |
Re: Axle Nut source
DIRECT PM to "barnfind08"....click the link BELOW! https://www.fordbarn.com/forum/priva...do=newpm&u=104 barnfind08 - OTHER Contact Info: Fred Wilner - ("barnfind08") SOUTHSIDE OBSOLETE 7136 200th St E. Faribault, MN 55021 (507) 332-6789 |
10-06-2022, 08:35 AM | #6 |
Re: Axle Nut source
Third Gen is the only source for a full line of "correct" hardware and fasteners for your early Ford. He even has Model A hardware. Third Gen is at Hershey this week. They will be back in the shop next week. |
10-06-2022, 08:49 AM | #7 |
Re: Axle Nut source
Thanks guys, I've sent a message to Barnfind08.
10-06-2022, 08:56 AM | #8 |
Re: Axle Nut source
10-06-2022, 07:11 PM | #9 |
Re: Axle Nut source
Buy a hard high nut and drill it for the pin.
10-06-2022, 07:21 PM | #10 |
Re: Axle Nut source
I got a hold of barnfind 08 and have two NOS Ford axle nuts on the way. Thanks for the help and information.
Tony |
