03-15-2022, 10:26 PM | #21 |
Re: You ever put a vacuum tank on wipers
Woodiewagon46, you say you used a vac. pump from a boat. where did you find your 6 volt vac. pump, and are they still available?
03-16-2022, 07:18 AM | #22 |
Alaska, I live on the North Shore of Long Island so marinas are all over the place. The vacuum pump I picked up was from a local marina back in about 1974. I don't know if they are still made in 6 volts or not.
03-16-2022, 08:42 AM | #23 |
I like the double diaphragm fuel pump option. I know they work because I drove a 48 home from Montana to Olympia that we had just bought only to find out later the manifold vacuum line had been removed and a plug put in the port. It rained most of the way home and the wipers worked nice although with a little stutter. These pumps seem a little harder to find for a ford V 8 but I see them at swaps time to time . Rebuild kits for them are still out there as well. Tim
03-16-2022, 09:56 AM | #24 |
I've got one of these on the truck. With the wiper motor rebuilt and the linkage properly lubricated, no problem.
