06-09-2022, 11:42 AM | #1 |
Pilot bearing journal diameter
What is the range of dimension for the main drive shaft pilot bearing journal? It's for a later transmission if that makes a difference.
06-09-2022, 12:16 PM | #2 |
Re: Pilot bearing journal diameter
The diameter of the hole for the 40 mm pilot bearing in the flywheel is 1.5738/1.5743 inches.
06-09-2022, 02:42 PM | #3 |
Thank you for the help.
06-10-2022, 06:15 PM | #4 |
You can buy a pilot bearing with a slightly smaller ID. then, assuming your input shaft is worn, it can be turned down and reused. Assuming the gears are good.
06-11-2022, 05:22 AM | #5 |
The transmission shaft should not turn in the pilot bearing, so the fit needs to be 0.001 to 0.003" clearance in my opinion. I recently restored a worn journal on a transmission shaft with JB Weld. After curing, I abraded the JB Weld to a diameter that was a snug fit into the pilot bearing. I have 100 miles on this fix, and so far it is working (no clutch chatter).
Bob Bidonde Last edited by Bob Bidonde; 06-11-2022 at 05:29 AM. |
06-11-2022, 05:26 AM | #6 |
06-11-2022, 06:18 AM | #7 |
The input shaft does turn in the pilot bearing anytime the clutch is depressed, otherwise you can't get it in gear.
06-11-2022, 10:41 AM | #8 |
That was ny first thought also but I think that Bob is correct in the close fit because it is a bearing not a bushing. So the rotational speed differences are made up in the bearing
06-11-2022, 10:57 AM | #9 |
IIRC, the originals were a bronze bushing, so the shaft would have to have been able to turn:
06-11-2022, 11:16 AM | #10 |
There was a person at the Portland Oregon swap selling re-machined shaft journal to fit a MM inside diameter bearing. FYI the original pilot bearing was/is used in many applications and easy to source. It was the same in my '66 mustang 6 cyl, and old Ferguson tractor.
06-12-2022, 12:21 PM | #11 |
An input shaft that is loose in the pilot bearing can and will cause your transmission to walk out of gear. It should be a machine fit, that is, no slop between the input shaft and the inner pilot bearing race...
06-12-2022, 12:41 PM | #12 |
The originals were ball bearings.
The front generator bearing is the same. 6203 2rs is a replacement number http://jmodela.coffeecup.com/bearings.html |
