Old 05-20-2015, 03:45 PM   #1
Ford_blue
Default Need to know the standard bore size of '28 Model A 4 Banger
Hey everyone! Newest member of the Ford Barn! I'm working on a friend's '28 Model A- engine was locked up so I removed the head and oil pan. Had a broken piston. He wants to get it running fast so I'm looking for a piston. This one measures 3.885" Cylinder bore size is 3.900" Is this stock? Also will need a head if anyone can help with that.
Thanks!
Ford_blue is offline   Reply With Quote
Old 05-20-2015, 03:55 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Need to know the standard bore size of '28 Model A 4 Banger
3.8750 is Standard bore. 3.9050 would be .030" oversized. Hone it a tad over the .005" and you should be close if the cylinder is round. Otherwise you need a .010 piston.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 05-20-2015, 03:58 PM   #3
BRENT in 10-uh-C
BTW, welcome to Fordbarn!!
BRENT in 10-uh-C
Old 05-20-2015, 05:55 PM   #4
colin1928
colin1928's Avatar
Brent is correct 3.8750 is std bore common piston over sizes today from most parts house are 0.020" 0.030 0.040" 0.060" 0.080" 0.100" 0.125"
colin1928 is offline   Reply With Quote
Old 05-20-2015, 07:43 PM   #5
James Rogers
James Rogers's Avatar
Where are you located? It would help on the head issue.
Old 05-20-2015, 11:28 PM   #6
Kurt in NJ
Kurt in NJ's Avatar
Make sure you measure at the bottom of the cylinder ---the piston has to be fit to the smallest part of the bore
Old 05-21-2015, 08:48 AM   #7
Mike V. Florida
Mike V. Florida's Avatar
Good luck and welcome!!
Old 05-29-2015, 01:57 PM   #8
Ford_blue
Thank you everyone for the warm welcomes! And I will take more measurements in the cylinder to make sure it is true. I am located in Southern Illinois- brought the head to a machine shop, but they said it had too many hairline cracks to repair..
Old 05-29-2015, 10:04 PM   #9
Mike V. Florida
They are plentiful and not expensive. I would suggest Berts in Denver for a used head that I'm sure would be in good shape. It would be a crap shoot from most other sources.
Old 05-30-2015, 06:29 AM   #10
fourbangerbob
I have a head I took off to install a hi-comp head. Ran good. $40.00 plus shipping from Minnesota
e-mail [email protected]
fourbangerbob is offline   Reply With Quote
