08-11-2012, 02:35 PM | #1 |
Max Stroke on standard 8ba Rods without grinding
Hi, what is the maximum stroke with stock 8ba rods .
I want to buy a Scat crank and use the stock rods. Don`t want to grind the block 4 1/8 ? Michael |
08-11-2012, 04:06 PM | #2 |
Re: Max Stroke on standard 8ba Rods without grinding
I know 4 1/4 will clear. That's the longest I have used with stock rods.
I built a 323 ci engine with 4 7/16 stroke and CAT rods. Had to grind the block .050. |
08-12-2012, 05:59 AM | #3 |
Pete,
Was it worth it? I want to turbocharge a 3 3/8 + 3 3/4. I havn't seen to many turbo set ups on flatheads. Chuck |
08-12-2012, 07:29 AM | #4 |
Chuck, Here is a neat one!!
08-12-2012, 01:21 PM | #5 | |
It was an interesting project. |
08-14-2012, 10:45 AM | #6 | |
Wow! I have to ask.... What cam did you use on the 323ci engine? Michael |
08-14-2012, 12:25 PM | #7 |
#4 Meyer Drake Offy. Very similar to the 404A Isky.
08-14-2012, 12:37 PM | #8 |
Pete - That's quite a mill! Great stuff.
08-14-2012, 06:35 PM | #9 |
08-14-2012, 06:50 PM | #10 |
Right angle drive gear box. Fuel pump on the left, tach drive on the right.
The right side will also take a power steering pump or a scavenger pump for dry sump depending on the application. |
08-15-2012, 01:07 PM | #11 |
May I ask what cylinder heads you are using?
Thanks! |
08-15-2012, 01:24 PM | #12 |
Edelbrock.
08-16-2012, 08:49 PM | #13 |
The engine above posted by oldford bellongs to George Perry of VT. The Frenzel blown engine is capped by twin plug heads and runs an L-100 cam. This drives an AOD trans into an 8" 4.11 rear. Yes the fear factor is quite hi when you mat this little duce roadster.
