10-16-2013, 07:14 PM | #1 |
factory oversized cam bearings?
Checked on my Flathead at the machine shop today. The owner who has done all of our machine work for years said that my 221 is the first block he has ever seen with .080 over sized cam bearings and he is positive they are factory. has anyone else ran into this? my block is 39 81-T
10-16-2013, 09:40 PM | #2 |
Re: factory oversized cam bearings?
Ford part # 01A-6261-D ---bearing camshaft front and rear--2.010 OD
Ford part # 01A-6262-D ---bearing camshaft center --2.010 OD The standard one has 1.928 OD Try Joblot automotive ---Dennis Carpenter --- |
10-17-2013, 06:06 AM | #3 |
I have the same oversize cam bearings in the 36 L-B engine I just tore down. If you find any I would like to know where, I will need some just have not started searching yet.
www.vonwelker.com https://www.flickr.com/photos/vonwelker/albums Home of the Blonde Bitch Bellytank |
10-17-2013, 08:22 AM | #4 |
I have those n.o.s.
10-17-2013, 07:23 PM | #5 |
I was going to suggest Fred, and up he pops. He is the go to guy on stuff like that.
10-17-2013, 08:59 PM | #6 |
10-17-2013, 09:16 PM | #7 |
were the over size bearings a fix a for cam journals that were not to spec?
10-18-2013, 04:49 AM | #8 |
I believe we are talking about the cam bearing bore ID in the block, not the journal size. Some bores cam oversize from Ford for some reason. Been discussed here before I think.
