Old 09-17-2021, 12:24 PM   #1
Vern
Vern's Avatar
Default Trick for removing oil pan singlehanded
As part of putting a new Burtz block in my roadster, I had to remove the oil pan from the old block. After draining the oil, I knew there was still oil in the drip pan and that the pump would drop along with the pan. Not wanting to drip more old oil onto the floor, I came up with a method of lowering the pan slowly and evenly. Taking a scissors jack, I put a thin wood board across the top, tied in place with zip-ties. I was able to get the pan low enough to slip the jack out, grab the pan and not make a big mess. Even so, I had a large pan filled with cat litter under the jack just to make sure.
Vern is offline   Reply With Quote
Old 09-17-2021, 12:29 PM   #2
Utopia Texas
Utopia Texas's Avatar
Default Re: Trick for removing oil pan singlehanded
Good idea Vern. As I get older I have to adapt and lifting and lowering cumbersome items requires a technique change!
Utopia Texas is offline   Reply With Quote
Old 09-17-2021, 12:30 PM   #3
PC/SR
There is a tool to hold the oil pump in place. Snyders part No. A 6621-R. Almost mandatory when putting the oil pump back in and reinstalling the pan.
PC/SR is offline   Reply With Quote
Old 09-17-2021, 01:36 PM   #4
700rpm
700rpm's Avatar
Some kitty litters are flammable. Make sure you are using clay-based litter, not bio-degradeable.
Ray Horton, Portland, OR
Old 09-17-2021, 03:47 PM   #5
scott_vt
scott_vt's Avatar
Smile Re: Trick for removing oil pan singlehanded
Hi Vern,
That sounds like a super idea ! I Don't plan on dropping the pan anytime soon, but that looks like it would work out well !
Thanks Scotty
scott_vt is offline   Reply With Quote
