Old 01-23-2019, 07:05 AM   #1
canadian
Default window regulators.
1929 Murray body Fordor. both front window regulators need replacing , originals not suitable for rebuild, what's thoughts on VINTIQUE...seems like only thing available. I have had a lot of negative results with this brand name replacement parts.
canadian is offline   Reply With Quote
Old 01-23-2019, 08:36 AM   #2
1930artdeco
1930artdeco's Avatar
Default Re: window regulators.
Spend the money and find originals.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 01-23-2019, 08:16 PM   #3
burner31
burner31's Avatar
Ditto post #2, and good luck finding them
Keith
Shawnee OK
'31 SW 160-B
Old 01-23-2019, 08:35 PM   #4
figment
Try Arizona Model A , Ask for Sammy . He has a lot of original parts and is quite reasonable .
figment is offline   Reply With Quote
Old 01-24-2019, 08:04 AM   #5
Del in NE Ohio
Del in NE Ohio's Avatar
I, like many, begin to wretch at the thought of using Vintique parts.. However when the Right Front ( same as Left Rear) regulator died in my 155-A Murray, I held my nose and installed one. It has been working fine for about three years now.
Del in NE Ohio is offline   Reply With Quote
Old 01-24-2019, 01:41 PM   #6
canadian
Hey Del that's a reassurance , in a bit of a dilemma with parts sometimes, on an island in cold North Atlantic I don't have a lot of options . I have purchased all my parts from vendors in USA. Always a little something when it came to Vintique, but just so happy to have a part so I could continue on, bought so much and cursed so much my 29 is named VINNEY. I ordered both regulators from Brattons, Vintique , so I am all ready for some filing, drilling ,twisting, grinding ,welding, cuts, bruises , bumps....but at least I get to sit on running board of a 1929 Model A and enjoy... thanks for you comment.
Old 01-24-2019, 06:03 PM   #7
Del in NE Ohio
I would rather use original regulator, but mine broke two days before my wife and I were leaving on a 9 day club tour. At the time, I was working at Snyders and could snag a repo off the shelf on my way to the parking lot. So far, so good. I had forgotten that I had replaced that regulator until I read your post.
Old 01-26-2019, 07:42 AM   #8
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
We forget that a Model A is a basically "DISPOSABLE" CAR!!!
Bill Wreckingyard
"THE ASSISTANT GURU OF STUFF"
Old 01-26-2019, 09:30 AM   #9
canadian
Bill , so glad to hear from you. One of the problems I am confronted with is parts availablity, just can't go and acquire the simple things even the MMO was a challenge and that is quite simple, We are on a Friggen rock in cold north Atlantic ...Jez are fore fathers would rather scale rocks and ice than over Sun and sand. CANADIAN DISCOURAGED.
Old 01-26-2019, 09:52 AM   #10
Oldbluoval
Oldbluoval's Avatar
Here's a band aid......
If the regulator gear has the "bad offs"
Take the cup apart and turn the gear over.
You'll get more service out of it.
If the spring brake is bad, you're just sorta out of luck without rebuild
NORS rebuild kits might be found and they are better than current
Old 01-27-2019, 12:02 PM   #11
hazelhoff
hazelhoff's Avatar
Vintique stuff is junk ! Bye regulators from Snyders, They are just fine. The Vintique ones don’t let the lower window rail pass, so you hear a lous click half was up and down.
Site matters ! Haha
hazelhoff is offline   Reply With Quote
Old 01-27-2019, 01:26 PM   #12
Purdy Swoft
Purdy Swoft's Avatar
I thought that Vintique was the only company that made the repeoduction window regulators . The times that I have used repro regulators , I've had to bend the arm on the regulator.
Old 01-27-2019, 01:44 PM   #13
canadian
from my research , Vintique is the only reproduction manufacturer of Fordor regulators
