Old 11-24-2019, 06:14 PM   #1
3739ford
3739ford's Avatar
Default Intake manifold bolts
Quick question, short answer.
Do the bolts for intake require a lock washer, flat washer, or no washer at all.
3739ford is offline   Reply With Quote
Old 11-24-2019, 06:56 PM   #2
qmdv
qmdv's Avatar
Default Re: Intake manifold bolts
Not sure what if anything is required. I kind of like alloy steel black oxide allen head bolts with SAE flat washer. Not close to stock but it looks good with aluminum intake.
qmdv is offline   Reply With Quote
Old 11-24-2019, 06:57 PM   #3
Kube
Kube's Avatar
Cast intake NO washers authentically. Aluminum intakes required hex head bolts and cadmium plated flat washers.
Old 11-24-2019, 08:13 PM   #4
3739ford
3739ford's Avatar
Thanks guys, it is a cast iron intake, really appreciate the responses.
Old 11-25-2019, 08:50 AM   #5
Bored&Stroked
Bored&Stroked's Avatar
There is no reason to NOT use a hardened flat washer - underneath a lock washer (at least that is how I do it). This helps prevent galling on the surface and makes for a bit nicer tightening/torque sequence. Now - if you're building a 100% perfect restoration, you'd need to do what Henry did - and I have no clue as to exactly what that is! What I do know is that the intake bolts from Ford are very specific to the intake manifold . . . easy to recognize even in a pile of hardware!
Old 11-25-2019, 01:19 PM   #6
3739ford
3739ford's Avatar
Bored&Stroked, my 39 pickup came with 8ba engine installed and this is what I thought was intake bolt.
