Old 07-30-2017, 09:39 AM   #21
Tom F OHIO
Tom F OHIO's Avatar
Default Re: Running with out shocks
I would say Chris is going to get shocks. How often should they be rechecked to be topped off with shock fluid? How do you know if the fluid is low.
Tom F OHIO is offline   Reply With Quote
Old 07-30-2017, 01:02 PM   #22
29er
29er's Avatar
Here's a really old thread that may be of interest:
https://www.fordbarn.com/forum/showthread.php?t=103387
29er is offline   Reply With Quote
Old 07-30-2017, 05:21 PM   #23
We1969knight
Thank you All for your reply'!
I understand that over half the A's on the road have no shocks.
I am a very careful driver and avoid rough roads (and RR tracks at any speed).
I think I'll eventually install orig. equipment shocks.
I understand there is a guy in Colo who rebuilds them.
Anyone have his contact info?
TIA chris
We1969knight is offline   Reply With Quote
Old 08-01-2017, 05:00 PM   #24
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
DUAL speed bumps are a great shock tester & also, those smooth drainage DIPS.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 08-01-2017, 07:19 PM   #25
H. L. Chauvin
Chris,
Running without shocks is like sleeping on the ground without bed springs.
After some time, you will get used to it.
H. L. Chauvin is offline   Reply With Quote
Old 11-04-2017, 08:26 PM   #26
Bikerider58
Bikerider58's Avatar
Just installed modern shocks on my 30. m.a.c.s_fabrication is ebay seller. I like the gas charged shocks over none.
Big improvement on worn originals. So, why modern? Although I think they are better, it came down to cost. Full set for price of one new original type.
No welding, no drilling and rear mount came be installed using front side longer rear backing plate bolts, so I can go back to original style whenever.
Bikerider58 is offline   Reply With Quote
Old 11-05-2017, 09:17 AM   #27
burner31
burner31's Avatar
Type in Ken Davis shocks
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
