04-07-2019, 06:57 PM | #1 |
battery
Are tractor supply 6 volt tractor batteries ok to use on our old cars?
04-07-2019, 07:04 PM | #2 |
Re: battery
If you buy the Group 1 it should fit and perform OK. I use NAPA Group 1 batteries in my old cars and get 7-8 years out of them. I’m careful to keep the water/acid leve topped off and charge them up once a month in the winter.
04-07-2019, 07:27 PM | #3 |
Re: battery
I 'm having a hard time getting a 6 volt battery lasting any more then 2 yrs so I heard about TSC and wondered if anyone had good/bad luck with them.
Thanks for the reply, Moe |
04-09-2019, 10:02 AM | #4 |
Re: battery
04-07-2019, 07:37 PM | #5 |
Re: battery
Do they have any group 2 or 2L batteries? Group 1 batteries are kinda small and I've never had much luck with them. Chevies, Plymouths, and old tractors, maybe, but old Fords used a larger battery.
04-07-2019, 08:02 PM | #6 |
Re: battery
Less than $100. SKU # 132347299.
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria |
04-07-2019, 08:39 PM | #7 |
Re: battery
Last Monday, the local TSC had a clearance sale on 6v positive ground batteries.
04-08-2019, 09:52 AM | #8 |
Re: battery
04-08-2019, 08:59 AM | #9 |
Re: battery
I went to "Batteries and Bulbs" and they have 6 volt for Ford Tractors and Model A. Bought battery for tractor. Price was reasonable.
04-08-2019, 10:35 AM | #10 |
Re: battery
Actually, there are "Positive" and "Negative" batteries. It has to do with the relative size of the posts.
04-08-2019, 10:39 AM | #11 |
Re: battery
Bought one for my Ford 8n there, it was in my tractor for about five years before I sold it, never had a problem with it.
04-08-2019, 10:44 AM | #12 |
Re: battery
04-08-2019, 05:54 PM | #13 |
Re: battery
that is what I said by writing orientation I guess I should have said size of posts but assumed that would be common sense they have been that way for at least 60 years and longer I only know of the ones I have owned ie big post+ negative-
04-08-2019, 06:06 PM | #14 |
Re: battery
i have a 6 volt optima in my merc my last one lasted over 10 years a friend of mine has one in his ford over 12 years
04-08-2019, 11:09 AM | #15 |
Re: battery
I have had Interstate 6v batteries since I returned to the road. One lasted 8 years, the next one only 2 years. i now am using an 8 volt Interstate, and find it is one of the best things I have done for my truck. You do not have to change any bulbs, and they are significantly brighter. It starts like a 12 volt battery. I started up the truck yesterday, after its winter hibernation, and never did anything thru the winter except to disconnect the ground cable.
Cheers, Byron.
IT'S NOT YOUR AGE, IT'S YOUR ATTITUDE ! |
04-08-2019, 11:56 AM | #16 |
Re: battery
Always wondered about 8 volts, but don't know anyone here in Ohio running one. Any more of you guys using 8 v batteries? mike
04-09-2019, 12:15 AM | #17 |
Re: battery
Just remember, you must adjust the the voltage regulator up to a charging voltage of around 9.5 volts to keep that 8 volt battery charged or it will likely die an early death due to sulfation, plus it won't have the reserve capacity it should have.
04-08-2019, 01:33 PM | #18 |
Re: battery
You will find a lot of negative post on them if you do a search.
04-08-2019, 04:58 PM | #19 |
Re: battery
The 8-volt is not necessary if the electrical system is correct and in good condition.
04-09-2019, 12:00 AM | #20 |
Re: battery
You could try using AA's > https://www.youtube.com/watch?v=0k1tbf8muMc
